What charge pipe connectors for <10psi
Old Apr 8, 2004 | 03:16 PM
biggmike2's Avatar
Default What charge pipe connectors for <10psi ?
please dont send me to home depot for rubber pvc connectors
Old Apr 8, 2004 | 03:24 PM
BoostedEM2's Avatar
silicone couplers are the best but can be pricey
Old Apr 8, 2004 | 03:26 PM
biggmike2's Avatar
Default Re: (BoostedEM2)
any place that has them cheap? silicone that is
Old Apr 8, 2004 | 04:28 PM
BoostedEM2's Avatar
Default Re: (biggmike2)
here are some places to get them........shop around
http://www.hosetechniques.com/
http://www.atpturbo.com/
http://www.extrememotorsports.com/g1cat/full.htm
http://www.roadraceengineering...s.htm
http://www.turbohoses.com/Couplers.htm
http://www.optauto.com/
Old Apr 8, 2004 | 04:36 PM
USDM 4G VTEC's Avatar
Default Re: What charge pipe connectors for <10psi ? (biggmike2)
well lets see
the real silicone deal i see them online all the time for about $14 ea
the home depot ones i have and so far they work great $3 ea
u make the math
Old Apr 8, 2004 | 07:01 PM
mos's Avatar
mos
Default Re: What charge pipe connectors for <10psi ? (USDM 4G VTEC)
Coolant hose should work fine.
For less than 10psi even those home depot sewer pipe connectors will probably be ok. At least for a while. Be sure to buy 1/2" smaller than you need. IIRC the ones that are called 1 1/2" fit 2" thin wall pipe well.
Old Apr 8, 2004 | 07:32 PM
B18bEK's Avatar
i would invest in t-bolt clamps so your piping isn't popping off every 2 days
Old Apr 8, 2004 | 07:49 PM
dunkd's Avatar
i bought the rubber home depot ones and they keep popping off @ 9psi on 294hp gsr... i just bought a 3ft long reinforced silicone tube for 40shipped.... PLENTY of couplings
Old Apr 11, 2004 | 08:01 PM
BoostedEM2's Avatar
if you have problems with the couplers popping off....a little trick is to spray some hairspray on the coupler and pipe. But not too much, or u will have to cut them off when you wanna take it apart cuz trust me......they will stick like a ****.
Old Apr 11, 2004 | 08:58 PM
mos's Avatar
mos
Thats how I put grips on my bikes. They slide right on, and after the stuff dries the grips aint going to shift at all. Spray paint works just as well as hair spray.
40$ for a large diameter length of silicone hose is really cheap. Care to share your source?
Old Apr 11, 2004 | 09:13 PM
dunkd's Avatar
http://www.ebay.com
Old Apr 11, 2004 | 10:11 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (dunkd)
yup hairspray is the ****
Old Apr 12, 2004 | 06:15 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">i bought the rubber home depot ones and they keep popping off @ 9psi on 294hp gsr... i just bought a 3ft long reinforced silicone tube for 40shipped.... PLENTY of couplings</TD></TR></TABLE>
Word. I bought a 2ft length of this for $25/foot and got 8 couplings out of it [3 inches long each]. This is the most inexpensive way to get good silicone couplings...I got mine from roadraceengineering.com
Old Apr 12, 2004 | 06:46 AM
steroidguy's Avatar
T-bolt clamps and Thermal Flex silicone couplers
Old Apr 12, 2004 | 07:11 AM
racinskittle's Avatar
Default Re: What charge pipe connectors for <10psi ? (steroidguy)
NAPA gasline hose This stuff is great! $15 a foot. I've got my D16z6 @ 10psi and it holds REAL well. Using standard clamps as well. They stick real tight to the charge pipes.
Old Apr 12, 2004 | 07:22 AM
quikB18B's Avatar
Default Re: What charge pipe connectors for <10psi ? (racinskittle)
http://www.atpturbo.com $6 a coupler Black/Red/Blue I think are the colors. I have black
Also get some t-bolt clamps while your at it. I have the ones from http://www.vecco.net $3.79 a piece, but thier is a place online called partssytems or something like that that sells em for like a $1 less a piece
Old Apr 12, 2004 | 07:53 AM
DaX's Avatar
DaX
Loved
Community Favorite
I bought my T-Bolt clamps from partssystems.com....like $2.75 each, and excellent quality.
Old Apr 12, 2004 | 09:28 AM
NapTownSi's Avatar
Default Re: (dunkd)
The Home Depot rubber couplers are only rated to 3-4psi. It states it right on the paper ring. You can't go wrong with ATP's silicone couplers, though! I bought two 2.75"-to-... reducers for my intercooler end tanks.
-Mark
Old Apr 12, 2004 | 11:02 AM
igo4bmx's Avatar
NAPA silicone couplers for radiators.
awesome and cheap for about 11-12 bucks a foot
holds up to like 30 psi and 500 degrees
Modified by igo4bmx at 3:23 PM 4/12/2004
OR_FAB
Welding / Fabrication
17
Jun 27, 2013 06:27 PM
OR_FAB
Jun 4, 2012 12:49 PM
jsw_1986
Apr 4, 2009 08:11 PM
NSfit
Sep 11, 2006 06:16 PM
more-fire-racing
Sep 18, 2005 08:19 PM
