Motec m4 and harness
They have a honda "kit". It's $2595.39 and comes with a base M4 box, custom harness that plugs into honda sensors, serial cable, and modified distributor. We do the kit for $3500 installed and dyno tuned. Don't forget, for a whopping $18 you can get the gm solenoid for boost control and have a boost by gear that actually works!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">They have a honda "kit". It's $2595.39 and comes with a base M4 box, custom harness that plugs into honda sensors, serial cable, and modified distributor. We do the kit for $3500 installed and dyno tuned. Don't forget, for a whopping $18 you can get the gm solenoid for boost control and have a boost by gear that actually works!!
im just curious... if the ecu comes with a harness that plugs into honda sensors...what is it exactly that you are charging 1000 in labor to do??
</TD></TR></TABLE>im just curious... if the ecu comes with a harness that plugs into honda sensors...what is it exactly that you are charging 1000 in labor to do??
Yeah, it plugs into the honda sensors, but it still takes time to install right. You still have to wire in the relays and hook up the tach output so the factory tach. You also have to wire in the speed sensor, as it's not hooked up on the motec harness. The rest is dyno time. There's alot to programming a motec...
tepid1
Nov 26, 2008 01:22 AM
