Did I get Type-R Springs?
Old Oct 26, 2001 | 01:49 PM
VTechie's Avatar
Default Did I get Type-R Springs?
I think that I just picked up a set of four Type-R springs. However, the guy I got them from had mixed them up with some other springs, so neither of us was completely sure which ones were which. I wound up taking the four that were shorter, and they all had a purple stripe as part of the paint code.
So here's the question: Does <U>anybody</U> know either the color codes or the uncompressed lenght and number of coils for 2000 ITR springs? I would appreciate the help VERY much!!
Old Oct 26, 2001 | 04:59 PM
Nighthawk GS-R's Avatar
New User
Default Re: Did I get Type-R Springs? (VTechie)
Yep itr srings are black with a purple/bluish strip on them
Old Oct 26, 2001 | 06:43 PM
VTechie's Avatar
Default Re: Did I get Type-R Springs? (Nighthawk GS-R)
Thanks a million- that's really a load off. One has pair has purple/blue/grey, the other has purple/green/blue.
Old Oct 26, 2001 | 07:05 PM
IN VTEC's Avatar
When I got my brand new ITR springs, they were about 13". The GS-R springs were 15" when I took them off.
Old Oct 26, 2001 | 11:50 PM
Mario's Avatar
Hey, I have GSR springs with the same markings.
Old Oct 29, 2001 | 05:23 AM
VTechie's Avatar
Default Re: Did I get Type-R Springs? (Supersonic DC2)
Can anyone else confirm this?
Old Oct 29, 2001 | 09:00 AM
Mario's Avatar
Well, you can definately figure out if the rear springs are from a Type R, because they are progressive and the coils would be closer together on top and further apart on the bottom. Also, there would be a plastic spacer surrounding the "dead" coils, which are the springs closer to the top.
There isn't really another way to identify the front springs other than putting it side by side by your OE springs and see which one has thicker coils. It should also be the shorter one too (which is what you picked right?).
Old Oct 29, 2001 | 10:42 AM
GSRacer's Avatar
New User
u got the right springs.
Old Oct 29, 2001 | 11:26 AM
VTechie's Avatar
Default Re: Did I get Type-R Springs? (GSRacer)
All right! Thanks so much you guys for calming my fears- I went out at lunch and measured them- 13" and 11.5", respectively, definitely progressive. And, yeah, there were those rubber bump-stops at the tight end.
Beers all 'round!!
HapiHonda
Jun 30, 2012 03:37 PM
Seann
Dec 16, 2002 10:36 PM
Amuse9
Oct 21, 2002 12:32 PM
Amuse9
Oct 20, 2002 04:15 AM
