Making crank suitable for high revs ?
Old Apr 8, 2004 | 09:48 AM
JoeyBallzSI's Avatar
Default Making crank suitable for high revs ?
Is there anything that can be done to a stock crank to help it to rev higher? Also what exactly is a knifed cranked? The application I would be using is k24 type s if that matters. Thanks guys.
Old Apr 12, 2004 | 06:27 AM
Default Re: Making crank suitable for high revs ? (JoeyBallzSI)
Some one has to have an answer to this question.
Old Apr 12, 2004 | 09:32 AM
Turbo RSX-S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoeyBallzSI &raquo;</TD></TR><TR><TD CLASS="quote">Some one has to have an answer to this question.</TD></TR></TABLE>
You asked a very complex question, yet probably do not even know it... The Rev issue has little to do with the construction of the crank, but more to do with the stroke to rod ratio, and rod angles. there is a world of information out there about this one, you have to just put your thinking cap on, and dig in...
Here is somewhere to start. http://www.theoldone.com
go to the archive section, and start reading.
Old Apr 12, 2004 | 09:42 AM
nickzed20's Avatar
Default Re: Making crank suitable for high revs ? (Turbo RSX-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo RSX-S &raquo;</TD></TR><TR><TD CLASS="quote">The Rev issue has little to do with the construction of the crank, but more to do with the stroke to rod ratio, and rod angles</TD></TR></TABLE>
so your telling me that the stock K24 crank wouldnt be as good for high revving as a shorter (stroke) crank made out of toothpicks? wow, thats a cheap alternative...
Old Apr 12, 2004 | 12:29 PM
krystar's Avatar
how fast do you need to go? with toda kit i think it takes it up to 9k. kit is with cams,springs, and ecu reflash
Honda_Fanatic
Nov 7, 2007 08:04 PM
Dr.Honda
Nov 3, 2007 03:33 PM
. a d a m
10
Aug 1, 2007 04:42 PM
xDicktonesx
Feb 14, 2006 07:29 AM
erebunicrx
May 19, 2005 07:04 PM
