SKunk 2 Coilovers Help!
What does the numbers on the coils represent?
I got a set of them, but i dont know what car its for?
the numbers on the coilovers are 0700.2.50.006 and 0700.2.50.008
if anyone knows a website where i can get this info that would be great or if u have the info on these it would also be better.
I check the skunk2 website but they dont show these #'s they show only the part # and its different from these.
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milton »</TD></TR><TR><TD CLASS="quote"> the numbers on the coilovers are 0700.2.50.006 and 0700.2.50.008</TD></TR></TABLE>
I'm not sure about the 0700.2.50 but I believe the .006 and .008 stand for the stiffness. IE the .006 is 6 kg/cm2 and the .008 is 8 kg/cm2.
they are for a civic!
here's a set i picked up off a buddy for cheap(drives a 00 Civic Si)
anyone care to explain how an integra would react with these coils on?(NOT slammed, with kyb agx)
Modified by skunkintegra at 2:41 PM 4/8/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 »</TD></TR><TR><TD CLASS="quote">.006 and .008 is integra/civic.... .008/.010 is eclipse, .012/.012 is accord/prelude.... it stands for guage of spring in some sense or another</TD></TR></TABLE>
.008 front and .006 rear are for civics and crxs, not integra. .010 front and .008 rear is for integra
maybe i'm just retarded.... .008/.010 integra .010/.010 or .010/.012 is eclipse....i forget. i put eclipse rate skunk's on a dc before.... was a little stiffer, but not too much
i belive i bought the same set for my DA integra. Didnt know they were for civics. i still put them on anyways with the .008 in the front and the .006 in the rear. i had them on tokico ulluminas. my friend with the same car had the correct spring rate and same setup and we couldnt even tell the difference. Had them on for 2 years and they still rock.
the 1st # is the spring length. 0700=7 inches
the 2nd # is the spring diameter. 2.50=2.5 inches
the 3rd # is the spring rate. 006=6kg/mm or 335lbs/in. 008=8kg/mm or 447lbs/in.
99redSIR
May 10, 2004 12:34 PM
