Where to get a type-s ball joint ?
Old Apr 8, 2004 | 07:08 AM
JMI's Avatar
JMI
Default Where to get a type-s ball joint ?
The dealer doesn't sell jut the ball joint. they want you to buy the knuckle with the joint. Anyone know where to get just a joint even if it's aftermarket.
Thanks,
Derek
Old Apr 8, 2004 | 08:26 AM
k20whitevic's Avatar
Nope, I've tried getting S ones as well as R ones directly from Japan. They can't be punched out according to about 10 people that I've tried getting them from, dealer included. You have to buy the whole assembly.
Old Apr 8, 2004 | 09:12 AM
stevel's Avatar
Default Re: Where to get a type-s ball joint ? (JMI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMI &raquo;</TD></TR><TR><TD CLASS="quote">The dealer doesn't sell jut the ball joint. they want you to buy the knuckle with the joint. Anyone know where to get just a joint even if it's aftermarket.
Thanks,
Derek </TD></TR></TABLE>
don't know about the type-s or the Si but I have replaced one on a 2001 Civic LX (Machpherson strut front like your cars) and the ball joint is a press fit just like the previous gen civic/integras and they can be removed quite easily. The dealer says they're not serviceable. I just went and bought a ball joint for an EK civic. Those ones have snap ring. They are a little taller so when you press (or hammer in) the balljoint it doesn't sit flush but you can get it in far enough to install the snap ring. It worked fine so far. You could also go to a junkyard and get a used knuckle.
s
Old Apr 8, 2004 | 09:16 AM
JMI's Avatar
JMI
Default Re: (k20whitevic)
What's the offset of the rims your running with the DC5-r knuckles ?
Old Apr 8, 2004 | 10:35 AM
I'm running a 40 which worked just fine with the S suspension, but now I need at least a 50, because they are thicker, and cause my front tires to stick out about a half an inch.
clutchmaster2005
May 10, 2007 08:09 PM
beav
Apr 15, 2007 08:23 AM
posHonda
Mar 24, 2007 07:36 PM
EnjoyTheRideDC2
Mar 16, 2006 09:04 PM
SRCivic97
10
Oct 12, 2005 03:17 PM
