what pistons can i use na?
Old Apr 7, 2004 | 10:38 PM
redloudlude's Avatar
Default what pistons can i use na?
does any one know what pistons i can use on a h22a block without sleaving it?
and can i use stock rods or should i buy rods too?
i want to go, na, for now 12 to 1 is that streetable ,what gains could i get just from that? 220 whp?
someone help....
Old Apr 7, 2004 | 11:19 PM
ensracer's Avatar
pistons will not make so much power. make sure you do not go to high im running a little over 12 and i have to run race fuel. my car will start stutering with pump gas... so be careful. youll get like 10 whp.
Old Apr 7, 2004 | 11:45 PM
so did you sleave and what pistons did you use i might go 11.5 to 1.
10 whp is good!
Old Apr 8, 2004 | 06:51 AM
h22mark's Avatar
Default Re: (eduardo)
What octane gas are you running, I hear 12 to 12.5 is fine daliy driven, could someone else chime in on this.
Old Apr 8, 2004 | 06:52 AM
what the...'s Avatar
Default Re: (redloudlude)
from what I've read, 11.5 is about the top end of 'streetable' pistons. Anything beyond that takes some tuning to work with pump gas. As far as sleeves go, it depends on your pistons. If you're getting forged (which you should, their lighter, better made) then you'll pretty much have to sleeve the block. There was a thread all about NA somewhere here...searching...
~edit: found
Old Apr 8, 2004 | 06:57 AM
h22mark's Avatar
Default Re: (what the...)
Ok, yeah your right sorry just misunderstood what you said in the previous post.
Old Apr 8, 2004 | 07:48 AM
SuperSlow's Avatar
Default Re: what pistons can i use na? (redloudlude)
I would take what "what the.." said pretty seriously. 11.5:1 seems like the max with some very goodtuning for pump gas.
Without sleeving, you may be the one lucky guy in a hundred who can coat forged pistons and get away with it.... but otherwise, only cast type-s seem to not shred and bond with the FRM.
SLEEVING, as in Sleeves of a shirt, coat etc.. What is sleaving?
the stock rods are pretty robust... and are also forged, I believe. So they will not be the weakest link.
Good luck, and do some searches, it will help you in your decision-making.
Old Apr 8, 2004 | 08:14 AM
93h22ajspec's Avatar
Default Re: what pistons can i use na? (SuperSlow)
yeah unless u get the type s pistons then you gotta sleeve your block cause any forged piston will shread it like a brick on tissue paper!
Old Apr 8, 2004 | 08:36 AM
Default Re: what pistons can i use na? (93h22ajspec)
also, a big factor in what parts you buy and where you start have to do with what your goal is. It seems that your goal is a high compression, street engine. I would save for sleeves and pistons, and get your valves done. then maybe do some head work. After this, get a V-AFC tune and make sure you're not lean anywhere. Then you can go with cams (if you want, but I've seen lots of people run stock cams and roll out nice numbers) and then any bolt ons will really add improvement. g/l with your build!
Old Apr 8, 2004 | 09:02 AM
Monkeyballs's Avatar
im running 11.5:1 pistons....and i just run top grade premium or super premium gas, and it runs fine....when i bought the car, the guy told me to run hi grade gas.....and also, i mean i have a h23 w/those pistons, pulleys, intake, exhaust.....what kinda tuning can i do? vafc? what good will it do?
Old Apr 8, 2004 | 11:07 AM
any one know a good place to find type s pistons with a ok price, and can i use stock
rods . whats the comp ratio on them
thanks for the help .
Jsarv
Welding / Fabrication
Jun 4, 2012 11:39 AM
fallbacdun
K Series
Oct 25, 2010 04:58 AM
young geezer
Aug 5, 2010 08:54 AM
hbkxtbone
Feb 15, 2005 06:14 AM
Loon
Jun 16, 2003 08:49 PM
