unorthodox pulley ?
Old Apr 7, 2004 | 09:24 PM
jackedcrew's Avatar
Default unorthodox pulley ?
hey i've had an unorthodox pulley for about 20,000 miles now and i've been hearing from a lot of people that after a while the pulley will harm my motor. now i know this is true but is this accurate for all people or do some get away with it. i know the stock pulley has a balancer in it so it wont vibrate like the after market pulley over time. i've also heard there is a way to adjust the pulley so it wont vibrate but i need some advise on how. if it comes down to it i can get rid of the pulley cuz i still have my stock one in the garage but it was cheap power and i'de hate to get rid of it. so is my motor gonna be fine with the pulley or should i sell it?
Old Apr 7, 2004 | 10:11 PM
vtecludeh22's Avatar
if u leave it on there for to long it will harm ur motor
Old Apr 7, 2004 | 11:52 PM
redloudlude's Avatar
it wont harm the motor,as long as its balanced and it is.
Old Apr 8, 2004 | 07:38 AM
makavelli1227's Avatar
dont listen to these ppl, it will not harm your motor, i have it and my motor is fine.
HOnda has just recently started putting those Harmonic vabrations on thier cranks, and before their cranks were fine.
And Honda is well known for having the most balanced cranks in teh car industry...so u have no worries in rebalancing.
Old Apr 8, 2004 | 07:52 AM
SuperSlow's Avatar
Default Re: unorthodox pulley ? (jackedcrew)
Honda motors are harmonically balanced internally. No probs with unorthodox or Aem... the only thing I have heard of is slipping, but you don't seem to have that problem. Have you noticed any gains from the pulley? dyno? I have been thinking of it, but I think before I go that route, I will just ditch PS and AC for free!
Old Apr 8, 2004 | 09:42 AM
Mike95lude's Avatar
Harmonic vibrations exist in the crankshaft even in properly balanced engines. A harmonic vibration frequency exists regardless of how well balanced your bottom end may be. The pulley is there to dampen this vibration and having perfect balance will not get rid of it.
Old Apr 8, 2004 | 10:15 AM
jackedcrew's Avatar
Default Re: unorthodox pulley ? (Mike95lude)
yeah it gave me a lot of torque and about the same amount of hp as my 68 mm throttle body. it's very easy to install and it's like 200 dollars too. im glad it's safe because my 1st and 2nd gear wouldn't be the same without it. thanks.
oh yeah and the pulley gives you almost double the power when you take your power steering off where as with your stock pulley it helps but not that much. it's like 3 lbs and like 5 inches in diameter where as your stock one is atleast 10 lbs and 8 or 9 inches in diameter. change the pulley you'll like it a lot especially if your going to take your power steering off. i drive with mine off cuz i dont think its that bad.
Old Apr 8, 2004 | 05:34 PM
fireslinge's Avatar
I was reading the product discription online and it said that "Removal of torsional vibration damper NOT necessary. " So as long as the damper is place it should be fine i think. (Though im still a noob)
This was for a 5th gen 'lude.
Old Apr 8, 2004 | 05:35 PM
fireslinge's Avatar
OK im an idiot that discription was for AEM's kit
Old Apr 8, 2004 | 09:59 PM
jackedcrew's Avatar
Default Re: (fireslinge)
yeah 5th gen lude.
Old Apr 9, 2004 | 10:04 AM
MugenPoweredLude's Avatar
well we'll never know until someone rips apart the motor after 20 or 30,000 miles with the UR Crank Pulley and takes a look at the bearings
it might be running fine yea but how are the bearings?
Old Apr 11, 2004 | 07:15 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (MugenPoweredLude)
on the north texas prelude owners board they have the results of a lude running this pulley.
Old Apr 11, 2004 | 07:20 PM
Kal's Avatar
Kal
Default Re: (cb7-R)
well i dunno if this can be compared but my friend's gsr who's running unorthodox pulleys has been good for 50k miles already...nothing's wrong with it.
Old Apr 11, 2004 | 07:37 PM
Inextricabledrvr's Avatar
i had a question about the crank pulley. Will the unorthodox crank pulley work with the AEM pulleys?
thanks
Modified by Inextricabledrvr at 11:47 PM 4/11/2004
Old Apr 11, 2004 | 08:55 PM
Hawkze_2.3's Avatar
Default Re: unorthodox pulley ? (Inextricabledrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Inextricabledrvr &raquo;</TD></TR><TR><TD CLASS="quote">i had a question about the crank pulley. Will the inorthodox crank pulley work with the AEM pulleys?
thanks</TD></TR></TABLE>
Yes, that's what I have on mine, you just have to figure out the belt sizes by putting a string or such around them when the pulleys are installed....Then just go to Autozone/OReilly and get the belts.....
Old Apr 11, 2004 | 09:24 PM
caLiH22A's Avatar
Default Re: unorthodox pulley ? (Hawkze_56)
Ok so everyone here is pretty much saying go for it, or keep the stock cranck pulley?
Old Apr 11, 2004 | 10:48 PM
did you notice a power gain anywhere?
Old Apr 11, 2004 | 11:01 PM
Hawkze_2.3's Avatar
Oh, definately...picks up quicker and pulls harder...same concept as a lightwieght flywheel, but with underdrive on the ALT and P/S....
Old Apr 12, 2004 | 12:14 PM
Default Re: (cb7-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R &raquo;</TD></TR><TR><TD CLASS="quote">on the north texas prelude owners board they have the results of a lude running this pulley.</TD></TR></TABLE>
Please get your facts straight
it was a knockoff of the pulley
Thanks
Old Apr 12, 2004 | 12:24 PM
EFz6er's Avatar
What where the results of the knockoff? Just curious????
Old Apr 12, 2004 | 12:37 PM
del_parker's Avatar
my UR crank pulley has been on for the past 35k miles. the motor has 190k miles on it now and the only thing i'm having issues with are the oil seals wearing out. which is bound to happen on any 12 year old motor.
hopefully i can get at least another 20k or so out of this motor.
Old Apr 12, 2004 | 12:51 PM
fast4w$'s Avatar
Default Re: unorthodox pulley ? (del_parker)
I've heard rumors and concerns about the lack of a H/B...
I have a UR crank pulley from when they first came out, about 5-6 years ago, and its been installed on both my old H23 and 3 years ago on my new H22, and it works just fine.
Old Apr 12, 2004 | 01:44 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenPoweredLude &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks </TD></TR></TABLE>
ok well its not a UR pulley but its similar. To those of you that didnt go to the site they said that it looked like the crank bearings took a beating. So those of you who say your engine is fine, you will only know for sure if you remove the bearings and inspect them.
Old Apr 12, 2004 | 02:36 PM
^^^basically what I said in my 1st post
Old Apr 12, 2004 | 03:17 PM
jackedcrew's Avatar
yeah this is one of the main reasons i asked because i saw this and started asking questions but it was a knock-off so i dunno. screw it though im keepin mine.
