Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
H22 EG with ITR sway bars, what is a good auto-x spring?
Old Apr 7, 2004 | 08:34 PM
. o 69 o .'s Avatar
Default H22 EG with ITR sway bars, what is a good auto-x spring?
After searching through the other posts i found in the archives, ive got a question about the sway bars. I got front and rear Type-R sway bars because i figured that the the rear will definitely help out understeer, and the front would add a more balanced feel to it. So now im trying to figure out what rate of springs to go with. I was reading that you want a stiffer rate for the back because of understeer, but with the swaybar, wouldn't a lower rate be a bit better? I dont wnat the back to get away from me under hard cornering, and i dont want to plow straight through. I have eibach porkit right now with stock itr shocks, and its definitely not cutting it. I am considering using Tokico Whites becaust they are one of the only shocks i could find for a reasonabl price. I'm looking at G/C, but really cant figure out the rates.
I know im running on and most likely not making sense, but its late, and i need to try to figure this crap out. Any help is great, and yes, BTW i did search
Old Apr 8, 2004 | 03:30 AM
.RJ's Avatar
.RJ
Default Re: H22 EG with ITR sway bars, what is a good auto-x spring? (B16B)
Pick something and go with it.... 300f/400r seems to go over well.
You'll change rates alot as you change the car and improve as a driver as well. The springs are cheap, especially if you pick 'em up used.
Old Apr 8, 2004 | 04:21 AM
. o 69 o .'s Avatar
Default Re: H22 EG with ITR sway bars, what is a good auto-x spring? (.RJ)
Strong Baaaaad!
anyways, do the springs actually have the rate engrave or stamped on or something? I am looking to go with ground control C/O... also should i take the front swaybar out so that the rear plays a bigger part or possibly put on a smaller front bar like an LS?
Old Apr 8, 2004 | 04:28 AM
.RJ's Avatar
.RJ
You can try the different sized swaybars.... there's no perfect setup, its all trial and error
The springs will be marked with #'s - http://www.norcalcrx.org/tyson/coilover.html
VarTheVar
35
Jun 23, 2018 05:23 PM
Falloutkid90
14
Jul 21, 2015 05:31 PM
tony413
Suspension & Brakes
Aug 22, 2008 08:35 AM
Maireeka
Suspension & Brakes
Apr 2, 2007 11:59 AM
Goodbye My Love
Suspension & Brakes
Jun 24, 2006 10:05 AM
