ITR cams with obd2?
Old Apr 7, 2004 | 07:50 PM
tbud454's Avatar
Default ITR cams with obd2?
I heard that with and obd2 ecu I will not get as much power out of the ITR cams in my b16 with bolt ons? I know the ECU will need to be chipped because I will be making power past the rev limiter. Im about to drop in some ITR cams and valve springs and retainers so i wanted to see if it was true. Thanks!
Old Apr 7, 2004 | 08:13 PM
tbud454's Avatar
Default Re: ITR cams with obd2? (tbud454)
anyone?
Old Apr 7, 2004 | 09:08 PM
TwistedSI's Avatar
They will make a good amount of power with factory ECU but if you can get a chipped OBD1 it makes even more.
Old Apr 7, 2004 | 09:48 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
to get the most out of the cams i would probably recomend getting a jumper harness and a chipped p28.. Try talking to Kenji on here he does really good work
Old Apr 8, 2004 | 06:54 AM
tbud454's Avatar
Default Re: ITR cams with obd2? (Jumpmann23)
anyone else?
paul8ex
Oct 3, 2007 09:05 PM
yellowbuffalo
Jun 16, 2002 07:43 AM
cr00klyn718
Mar 17, 2002 02:39 PM
redteg1
Mar 6, 2002 09:15 PM
