Need help with my Electrical system.
Old Apr 7, 2004 | 06:38 PM
KooK's Avatar
Mustang Sally
Default Need help with my Electrical system.
I really don't wanna clutter up the kills form with Tech stuff and I can't post it anywhere else because its not a Honda. But I'm posting it here because you guys have helped me solve most all of my problems. So if you could help me out here that would be freakin great.
Anyway, its an 00 Mustang GT and I have a weird problem. I got my alternator tested out twice and tried a friends alternator once, so my alternator I'm pretty sure is good, I checked all my fuses under the hood and got my battery tested. All good. But for some reason, my Electrical system wont charge or run off the alternator. It just drains to battery like the alternator is completely dead.
Anybody have any guesses?
Old Apr 7, 2004 | 06:48 PM
civickiller's Avatar
Default Re: Need help with my Electrical system. (KooK)
check for continuity between the battery and the alternator, there should be, if not you got a break in the line someplce. also make suer all your grounds are on the car
Old Apr 7, 2004 | 07:33 PM
deepgreengsr's Avatar
Default Re: Need help with my Electrical system. (civickiller)
<U>F</U>OUND <U>O</U>N <U>R</U>OAD <U>D</U>EAD
jk.. its prolly not pluged in correctly or your voltage regulator is dead. if its pluged in correctly its the voltage regulator. just replace it.
Old Apr 7, 2004 | 07:39 PM
KooK's Avatar
Mustang Sally
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">check for continuity between the battery and the alternator, there should be, if not you got a break in the line someplce. also make suer all your grounds are on the car</TD></TR></TABLE>
HERES THE COMMENT THAT SAVED ME!!!
I've checked the main power wire from the alternator but I didn't check the wires to the voltage regulator. Well, I checked them and found out both wires were broke somewhere. I ripped apart my harness to trace it back and find out that theres a plug hidden under my fuse box that wasn't plugged in... BAM...
I've had dumber problems but this one ranks up there.
Thanks guys!
eggie75
Mar 25, 2010 04:37 PM
jauldredge
Jul 22, 2008 06:40 AM
obuhmyuh
May 28, 2008 03:27 PM
duyfash0
Dec 16, 2006 01:10 PM
biggdogg
Apr 25, 2004 07:03 PM
