obd-2 lsvtec tech help
Old Apr 7, 2004 | 06:21 PM
DohcVtecCrx's Avatar
Default obd-2 lsvtec tech help
Background:
97 ls integra. b18b bottom end w stock bore pr3 pistons, acl bearings, arp rod bolts, arp head studs, pr3 b16a head and intake manifold, obd-2 gsr distrib, stock obd-2 ls: injectors, map, tps (adjusted to .40 closed 4.54 WOT). Stock ls tb, header, gsr tranny. Compression test good.
Problem:
Using either an obd-2 ITR ecu or a harness and a obd-1 p30 ecu the car runs like ****. Has no low end or no top end, idles shitty, seems to run rich. With the stock ls ecu it runs very strong low end and mid range (till rev hits LOL). With the ls ecu I get a code 54 for the sensor on the oil pump which has been removed since it is running a dohc vtec oil pump. With the itr ecu and the p30 ecu it has a knock sensor code. No other codes or problems whatsoever.
any thoughts on what the problem could be?? I am gonna change the plugs because I'm not sure the right ones are in it but after that I am stumped.
Old Apr 7, 2004 | 06:58 PM
torr's Avatar
Default Re: obd-2 lsvtec tech help (DohcVtecCrx)
look into purchasing a chipped p28 ecu, i've never actually met anyone with a ls/vtec running a stock ecu that ran well.
Old Apr 7, 2004 | 07:44 PM
Default Re: obd-2 lsvtec tech help (torr)
that is why I have the conversion harness so I can get a p28, but there has to be a reason this one is not running decent with 2 dohc vtec ecu's and good with an ls
Old Apr 16, 2004 | 09:56 PM
99lsvtecauto's Avatar
did u adjust the valves its not going 2 run right on the p30 or p72 with no ks ks codes throws off idle and retards timing did the ls oil pump sensor not fit why isnt it connected idle can be effected by cams which 1 r u using what c/r
Old Apr 16, 2004 | 11:55 PM
blackdude's Avatar
the type r ecu could run like **** because of the knock sensor
code.
Old Apr 17, 2004 | 08:00 AM
Default Re: obd-2 lsvtec tech help (blackdude)
the p30 would do the same thing they r both throwing codes 4 ks
blackeg
Jul 7, 2013 10:05 AM
tk978
13
Oct 2, 2010 09:47 AM
sk8board{Pete}
Nov 29, 2008 03:45 PM
wascly
Feb 3, 2006 08:05 PM
DohcVtecCrx
Apr 8, 2004 02:08 PM
