Blue Smoke - How To Fix?
Old Apr 7, 2004 | 04:57 PM
ZoominTeg's Avatar
Default Blue Smoke - How To Fix?
I kno blue smoke is oil burning, thats the only thing the search gave me, that its burning oil. How would I fix this? New piston rings? If not, how would I find out what IS burning the oil?
Old Apr 7, 2004 | 05:19 PM
King_j's Avatar
Default Re: Blue Smoke - How To Fix? (ZoominTeg)
many things. rings, valve guides,
Old Apr 7, 2004 | 05:22 PM
tilt's Avatar
you can do a leakdown test.
Old Apr 9, 2004 | 10:03 AM
ZoominTeg's Avatar
Default Re: Blue Smoke - How To Fix? (tilt)
Can you explain it a little more? Or where I can read on this. I dont want to spend money on oil and smell burning oil :-x.
Old Apr 9, 2004 | 10:08 AM
SuzukaBlueAP2's Avatar
When is it burning ? And you never said, but, I'm guessing it's coming out of your exhaust ??
You gotta describe your whole situation a little better if you want solid help.
Old Apr 9, 2004 | 10:14 AM
Yambor's Avatar
Default Re: Blue Smoke - How To Fix? (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">When is it burning ? And you never said, but, I'm guessing it's coming out of your exhaust ??
You gotta describe your whole situation a little better if you want solid help.</TD></TR></TABLE>
exactly for example if it happens when you start up your car its most likely the valve seals..
does it burn at high rpms?
inbetween gears?
when you let off the throttle?
Old Apr 9, 2004 | 06:32 PM
ZoominTeg's Avatar
Default Re: Blue Smoke - How To Fix? (Honda2nr4life)
Sry . Higher rpms, and it does as its warming up, and I'm sure its not white smoke that normally comes out, after it warms up it stops. Should I get some of that 70k mile reconditiion my seals, I mean does that stuff actually work?
Old Apr 9, 2004 | 06:53 PM
Comp97GSR's Avatar
At high rpms also, I would put my $$ on the rings.
Old Apr 9, 2004 | 07:39 PM
mrmonk's Avatar
Default Re: Blue Smoke - How To Fix? (Comp97GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">At high rpms also, I would put my $$ on the rings.</TD></TR></TABLE>
yeah most likely
Black Smoke = burning oil = cracked head
Blue Smoke = burning coolant = rings gone bad
Old Apr 9, 2004 | 08:41 PM
G1 TEGGY's Avatar
Default Re: Blue Smoke - How To Fix? (mrmonk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmonk &raquo;</TD></TR><TR><TD CLASS="quote">
yeah most likely
Blue Smoke = burning coolant = rings gone bad</TD></TR></TABLE>
wouldn't burning coolant be more cracked head and WHITE smoke? blue smoke is oil burning and bad rings, think you might've gotten switched up there... rings/pistons, could be worn rings or could be piston damage.. expect about $300 for DIY about $450-500 for shop to fix.
EDIT: ScreaminTeg is right, coolant is white smoke, many apologies
Modified by G1_TEGGY at 10:38 PM 4/10/2004
Old Apr 9, 2004 | 10:14 PM
Default Re: Blue Smoke - How To Fix? (G1_TEGGY)
Just to set the record straight here...
Blue smoke = oil burning
Black smoke = rich air/fuel mixture
White smoke = coolant burning
Old Apr 10, 2004 | 02:55 PM
ZoominTeg's Avatar
alright, thanks guys
Old Apr 10, 2004 | 02:57 PM
JBBNJ609's Avatar
but black smoke could also be running RICHLY .....
JBBNJ609's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">Just to set the record straight here...
White smoke = coolant burning </TD></TR></TABLE>
Old Apr 10, 2004 | 02:59 PM
G1 TEGGY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZoominTeg &raquo;</TD></TR><TR><TD CLASS="quote">alright, thanks guys </TD></TR></TABLE>
hey no prob, if you're gonna DIY for the repair hit me up for some pointers, always willing to help.
dvd5904
74
Apr 5, 2010 05:49 AM
B18cFreak
Apr 17, 2007 02:04 PM
dexGSR99
Feb 6, 2006 04:27 PM
viprcr1
Mar 5, 2004 02:32 PM
stockgreencivic
Apr 26, 2003 02:41 AM
