Service Check Connector
Old Apr 7, 2004 | 04:41 PM
JV's Avatar
JV
Who?
Default Service Check Connector
Not the most interesting tech question, but...
I was set the timing on my 95 Civic EX today. Well when i was looking through the service manual, it said to located the white/green and brown, two terminal connector (Service Check Connector) behind the kick panel, next to the ECU. I found what i thought to be the connector, but instead of the wires being white/green and brown, there was one black and one brown wire going to the connector.
Just for my own personal knowledge, what color wires make up your 5th gen civics service connector? I just want to be positive i am jumping the right connection.
Old Apr 7, 2004 | 04:49 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Service Check Connector (JV)
The colors may not be the same. On my EG (1993) the colors are green/white and brown/black. It will be right under the passanger side of the dash. There will also be a 3 pin connector right by it. Usually they are plugged in to this green rubber housing. Anyway, if it is by a 3pin and there is nothing connected then you have the right one. Enjoy and happy tuning...
Old Apr 7, 2004 | 06:13 PM
JV's Avatar
JV
Who?
Default Re: Service Check Connector (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">There will also be a 3 pin connector right by it. Usually they are plugged in to this green rubber housing. Anyway, if it is by a 3pin and there is nothing connected then you have the right one. </TD></TR></TABLE>
Yep that's the one i found. I wonder if they changed the colors from year to year?
Old Apr 10, 2004 | 05:40 AM
They usually don't but I mean production at Honda plants isn't going to stop if they run out of a certain color wire. They will swap in somethings different for a group of cars until the proper color is delivered.
Old Apr 10, 2004 | 05:57 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I've seen blue and green connectors before too. Wire colors are not always the same either.
As long as it's a two-pin connector, you should be good to go.
Old Nov 22, 2013 | 10:57 AM
baceman007's Avatar
Yeah, just an FYI to backup some of the other posts here. On my 1993 Civic del Sol the connector is in a green boot on the passenger's side. It is a 2-wire connector green and then brown.
Old Nov 22, 2013 | 11:02 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Don;t bump a 9 year old thread.
chad
Jun 14, 2008 08:05 AM
mcgee*
Mar 20, 2007 05:31 PM
Nerologic
Jul 11, 2004 03:54 PM
lahight
Mar 6, 2003 01:02 AM
Jeager521
Audio / Security / Video
Oct 20, 2002 10:49 AM
