12's posible on street tires?
Old Apr 7, 2004 | 09:10 AM
Dr Honda's Avatar
Default 12's posible on street tires?
Hi All,
the local track (Keystone raceway) is going to open on april 17th and I was going to go to see what my car is capible of.
my set up right now is a Del Sol powered with a B16a3, and it's boosted to 11 psi with a T3 super 60. (intercooled, BOV, 450's, ect)
OK... the car may not have enough HP to be able to pull 12's... but if the HP is there... can it be done on street tires?? (Zeik 512 205/50/14) mid 12's was my goal for this project.
Thanks
Old Apr 7, 2004 | 10:08 AM
EVIL TYPE R's Avatar
Default Re: 12's posible on street tires? (Dr Honda)
if the power there yes it's possible...I've seen many cars baby it out of the hole then get on it and run 12's
Old Apr 7, 2004 | 12:57 PM
GPwhiteDB8's Avatar
yeah you can do it......u can run 11's in a hatch on street tires if u really want to. well u can run 11's on bfg's....how much power are u making though? not to burst ur bubble but odds are you'll be in the 13s
Old Apr 7, 2004 | 03:08 PM
12SecHatch's Avatar
Default Re: (EG-UNIT)
13.0's with worn street clutch BFG'S
12.5 decent 6puk clutch slicks
sohc vtec stock internals, fmax turbo kit
Old Apr 8, 2004 | 06:42 AM
Dr Honda's Avatar
Nope... no bubbles bursted. I don't know how much power the engine is makeing yet. I got the turbo done just in time for winter to hit last year (so it's been parked)... and now I'm doing the tunning. (on the street with a wideband) I guess my goal for power would be right around the 300 whp mark.
I know if I get a good clutch and slicks I can get into the 12 eventualy with practace and tunning... but I'm not looking to maximize my drag times... I'm looking to make a fast street car (relitvly fast) So, for me... it has to be with what ever tire I'm going to run on the street. I was just wondering if 12's are possible.
thanks for the input so far. Anyone else??
Old Apr 8, 2004 | 06:50 AM
Used2beAb16's Avatar
Default Re: (Dr Honda)
I live near the keystone area so ill probably see you up there running on Weds if u going to test and tunes.
I noticed you said your doing your tuning on a wideband. Which wideband is it? How much was it? Do you have a link? Did you just install another 02 sensor bung for it?
Old Apr 8, 2004 | 12:27 PM
dunkd's Avatar
are azenis and bfg's considered street tires?
Old Apr 8, 2004 | 01:16 PM
TurboJesse
Guest
Posts: n/a
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">are azenis and bfg's considered street tires?</TD></TR></TABLE>
yes...bfg's are in a different league than azenis's though...too much wheel hop with azenis, there sidewalls aren't meant for 1/4 mile..
Anyways yes you should be able to run 12's fairly easily on street tires with ~300WHP.
Old Apr 8, 2004 | 03:28 PM
H25's Avatar
H25
Default Re: (Mpir3)
Yes its possible and We were the first to build a 12 sec radial tire all motor honda . this was ran at carlsbad raceway about a year ago in my customers crx with a 1.8 b18c1 on falken azenis. first pass. 12.90@112.4mph...
Old Apr 8, 2004 | 03:49 PM
jinxproof99's Avatar
New User
Default Re: (MHRacing-310)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MHRacing-310 &raquo;</TD></TR><TR><TD CLASS="quote">Yes its possible and We were the first to build a 12 sec radial tire all motor honda . this was ran at carlsbad raceway about a year ago in my customers crx with a 1.8 b18c1 on falken azenis. first pass. 12.90@112.4mph... </TD></TR></TABLE>
first in california........
Old Apr 8, 2004 | 03:52 PM
DIRep972's Avatar
Smarter than you
yeh its pretty easy actaully, if you run on bfg's.. If you car can do 110mph in the 1/4 then u should be able to hit 12's and if u don't u can't drive.
Old Apr 8, 2004 | 04:46 PM
nekkedR's Avatar
Default Re: 12's posible on street tires? (DIRep972)
as long as you can keep the wheel spin under control you should be ok. another car from greensburg with a 60-1(9psi) went 13.0 on falkin azenis.
Old Apr 8, 2004 | 05:21 PM
H25's Avatar
H25
Default Re: (jinxproof99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinxproof99 &raquo;</TD></TR><TR><TD CLASS="quote">
first in california........ </TD></TR></TABLE>
I dunno about that one.. I had built the b18c1 for billy loyds crx back in 2002. I dont remember any street car runninh those times on RADIAL's, not any type of drag radial.. because if thats what you ment then that to me is entirely different. a drag radial is much closer to a slick then a actual street tire... I just said we were the first to do it on normal radials..
quicksi69
Suspension & Brakes
Oct 30, 2009 02:48 PM
slowsol95
Feb 5, 2007 09:17 PM
boosted1993
Aug 17, 2003 09:34 AM
ALLMOTOR18
Jul 22, 2003 10:38 PM
eg6turbo
Apr 18, 2003 04:58 PM
