oil dripping somewhere
Old Apr 7, 2004 | 08:50 AM
.M.'s Avatar
.M.
Default oil dripping somewhere
oil is dripping somewhere around the back end of the car or something. there is little bits of oil on the cement around the front of rear wheel and near there somewhere.. what could the leak be?
Old Apr 7, 2004 | 08:55 AM
SuzukaBlueAP2's Avatar
Default Re: oil dripping somewhere (JH4DC4)
does it resemble brake fluid ? (which is an oily substance)
If so, it could be a blown shock, a brake fluid leak, or oil that is actually leaking from under the engine bay somewhere, and while you are driving it is running to the rear of the vehicle.
Old Apr 7, 2004 | 09:03 AM
631 Teggy's Avatar
Default Re: oil dripping somewhere (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">does it resemble brake fluid ? (which is an oily substance)
If so, it could be a blown shock, a brake fluid leak, or oil that is actually leaking from under the engine bay somewhere, and while you are driving it is running to the rear of the vehicle.</TD></TR></TABLE>
Everything he said
You can't just expect us to know what it is... You're going to have to jack up the car and find out exactly where it is coming from. If it isn't a severe drip then you may not even notice mechanically... As far as engine oil... Probably not...
Old Apr 7, 2004 | 09:15 AM
.M.'s Avatar
.M.
Default Re: oil dripping somewhere (631 Teggy)
it could possibly be the shocks.. because mine are dead.. but i've been losing engine oil somewhere and i dont know where it is all going. i just did an oil change like 2 months ago and i checked the oil yesterday and it was almost done. i've started noticing these drips and was wondering wehre all this engine oil has gone.
Old Apr 7, 2004 | 03:33 PM
.M.'s Avatar
.M.
upp!! could it be the oil pan and **** like that? i checked the bottom of the cement and the oil seems to be around the oil pan and on the right side near the header...
Old Apr 7, 2004 | 03:43 PM
631 Teggy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JH4DC4 &raquo;</TD></TR><TR><TD CLASS="quote">upp!! could it be the oil pan and **** like that? i checked the bottom of the cement and the oil seems to be around the oil pan and on the right side near the header...</TD></TR></TABLE>
Then yeah, if you're not burning oil (bluish smoke from the exhaust), then you are dripping oil... You said it was near the rear wheels first...
If it is dripping from the oil pan, get UNDER THERE, and find out where from. Probably either the oil filter or oil pan gasket...
Old Apr 8, 2004 | 10:10 AM
.M.'s Avatar
.M.
how long can i run with the oil dripping? im low on money right now..maybe a month or so before i can change it.. will it hurt the engine in anyway?
Old Apr 8, 2004 | 11:27 AM
LowTEC SaiMike's Avatar
i wouldn't ride on blown shocks........ don't want to hurt ur car struts and chasis..........
Old Apr 8, 2004 | 12:03 PM
631 Teggy's Avatar
Default Re: oil dripping somewhere (BomBoi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BomBoi &raquo;</TD></TR><TR><TD CLASS="quote">i wouldn't ride on blown shocks........ don't want to hurt ur car struts and chasis..........</TD></TR></TABLE>
It's engine oil... He said it was coming from the oil pan... Just keep throwing in oil... It will be fine as long as you keep the oil level up... If not then you can do a lot of unnecissary wear and tear...
Old Apr 8, 2004 | 12:49 PM
aznballer's Avatar
yeah purchase sum extra oil and throw it in the trunk just incase u go low
aemciv
Aug 25, 2017 05:46 AM
jp41
Oct 8, 2015 10:04 AM
cgaleema
May 22, 2011 08:59 AM
mobeoner
Oct 18, 2008 12:30 PM
return_2020
Apr 19, 2005 12:31 PM
