using a "plug and play" unit for my 01v6,. is it worth it??
Old Apr 7, 2004 | 07:30 AM
sleeperaccordv6's Avatar
From: west Ft.Worth, Texas, the big one in the center
Default using a "plug and play" unit for my 01v6,. is it worth it??
basicly just what the title says. I was wondering if it would improve anything
or waist money? looking at the VENOM 400
Old Apr 7, 2004 | 07:33 AM
-RedneckDave-'s Avatar
Working
Default Re: using a "plug and play" unit for my 01v6,. is it worth it?? (sleeperaccordv6)
Probably just a waste but you never know until you try. If it does not replace the ecu then i would say it is a waste on these cars.
Old Apr 7, 2004 | 07:56 AM
Default Re: using a "plug and play" unit for my 01v6,. is it worth it?? (01accordv6)
right on.. I'm trying to get my "boat" faster without breaking the bank,. and
I'm not looking for a rocket (nor expecting it). one other thing is that it realy needs
to be tuned, what kindof place should I take it? ie. a "performance" shop or to an
import only type shop?
Old Apr 7, 2004 | 08:09 AM
KTeller8's Avatar
header..
get a good header and it makes all the world of difference
Old Apr 7, 2004 | 08:26 AM
Default Re: using a "plug and play" unit for my 01v6,. is it worth it?? (KTeller8)
I'll look into it. who should I go through?
Old Apr 7, 2004 | 07:31 PM
Working
If the funds are not a prob then get the comptech ones they are bad ***. If not then get the OBX ones.
Old Apr 8, 2004 | 04:02 AM
wutthebun's Avatar
i have the Venom PCM 400 installed on my 99 V6 sedan. too tell you the truth its not worth the 300 dollar price tag. but u will fell a drastic change in ur driving..
Old Apr 8, 2004 | 07:19 AM
matix's Avatar
For 300 dollars you could have got some real ponies buying a used zex nitrous kit.
Old Apr 8, 2004 | 01:37 PM
Default Re: (matix)
no nitrous.....who sells OBX pipes? what are the #'s
Old Apr 8, 2004 | 01:48 PM
Default Re: (sleeperaccordv6)
How hard is it to install gauges on our car? mostly want trans. temp, oil temp, engine...
no real performance reason but I just want to know whats going on under there....
Old Apr 8, 2004 | 04:36 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperaccordv6 &raquo;</TD></TR><TR><TD CLASS="quote"> How hard is it to install gauges on our car? mostly want trans. temp, oil temp, engine...
no real performance reason but I just want to know whats going on under there....</TD></TR></TABLE>
pretty easy..just need locate all the sensors, installation is pretty straight forward for most of the honda
Old Apr 8, 2004 | 04:38 PM
ttt
digital sol
Mar 29, 2007 02:32 PM
SSS
Welding / Fabrication
Oct 18, 2005 01:10 PM
'99luder
Jun 9, 2004 01:08 PM
io_burn
Jan 15, 2003 03:25 PM
