What is the stock fuel pressure on a 98 itr? What lph is the stock pump?
Old Apr 7, 2004 | 05:04 AM
mrtrex's Avatar
Default What is the stock fuel pressure on a 98 itr? What lph is the stock pump?
Thanks for the help!
Old Apr 7, 2004 | 05:27 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: What is the stock fuel pressure on a 98 itr? What lph is the stock pump? (mrtrex)
190 lph if I'm not mistaken.
Old Apr 7, 2004 | 05:39 AM
EleanoR's Avatar
stock fuel pressure is 47-53 PSI vacuum off I believe
Old Apr 7, 2004 | 12:53 PM
mrtrex's Avatar
Default Re: What is the stock fuel pressure on a 98 itr? What lph is the stock pump? (EleanoR)
anyone know for sure?
Old Apr 7, 2004 | 01:06 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtrex &raquo;</TD></TR><TR><TD CLASS="quote">anyone know for sure?</TD></TR></TABLE>
Both of the above seem to be correct.
Old Jun 1, 2004 | 09:25 AM
Boosthead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EleanoR &raquo;</TD></TR><TR><TD CLASS="quote">stock fuel pressure is 47-53 PSI vacuum off I believe</TD></TR></TABLE>
What do you mean by vacuum off?
Old Jun 1, 2004 | 09:31 AM
B2FiNiTY's Avatar
Default Re: What is the stock fuel pressure on a 98 itr? What lph is the stock pump? (Boosthead)
With the vacuum hose OFF.
Old Jun 2, 2004 | 04:27 PM
CivicTypeR00's Avatar
Default Re: What is the stock fuel pressure on a 98 itr? What lph is the stock pump? (B2FiNiTY)
no way stock itr fuel pressure is that high, stock b16 fuel pressure is like 35-37. and when he says vacuum off that would be the fuel pressure at idle because obviously the pressure increases as you rev your engine.
Old Jun 2, 2004 | 04:31 PM
Austin's Avatar
Default Re: What is the stock fuel pressure on a 98 itr? What lph is the stock pump? (CivicTypeR00)
Stock itr fuel pressure is 47-53psi, hose off...take a look in the helms manual. Ever wonder how Honda uses 240cc/min injectors on all of the B-series engines...they increased the fuel pressure.
Austin
sleepin91teg
Jun 16, 2004 05:13 PM
SOFLSOL
Feb 24, 2004 03:42 PM
TrboInteg
Oct 26, 2003 06:57 PM
01itr518
Jan 8, 2002 12:17 PM
nsx-Animal
Sep 7, 2001 12:28 PM
