Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Q's on wiring a racecar
Old Apr 6, 2004 | 06:03 PM
teg92's Avatar
Default Q's on wiring a racecar
When simplifying a wiring harness on a race car, I want to retain the engine harness, and the ECU part of the main harness. Fuel, Ignition, ECU, Lights, etc will be wired independantly of the original ECU harness. My question is, can everything but the ECU harness be eliminated as long as the fuel pump, ECU and ignition have power, or is the ECU dependant of the PGMFI relay?
Also, for anyone who has done wiring on a DC, on the 14 pin connector (C304 and C127 I believe) on the drivers side firewall in the engine compartment, do the injector wires (pins 1-5 on ECU connector A) lead back to the ECU harness clip through the interior side of the firewall or the exterior side of the firewall?
Old Apr 6, 2004 | 07:28 PM
1 2 NV's Avatar
Default Re: Q's on wiring a racecar (teg92)
well as a matter of fact, i have a gutted harness. my turn signals, tach, fuel level indicator (if i had a fuel tank), parkin lights, brake lights, clutch safety switch and speedo still work. ill b honest though, its alot of work, alot of wasted time for the little weight that gets shaved.
Old Apr 6, 2004 | 07:34 PM
Speedz's Avatar
Default Re: Q's on wiring a racecar (1 2 NV)
hey richie i'll do some research for u on my side.. been super busy building motors and such.. keep researching too..
what1118
Dec 15, 2007 07:00 PM
jaydmef8
Aug 9, 2007 03:09 PM
chippedrex
Jun 23, 2004 05:37 PM
