94 Accord EX reaar brake problem
Old Apr 6, 2004 | 05:26 PM
funkmd's Avatar
Default 94 Accord EX reaar brake problem
Hey all, I'm a n00b here but I hope you can help
I was replacing my rear pads today when I noticed on the caliper assembly that one of the "slide gromets" (best guess at what they are called) was seized
I can get the pads in and the one side is fine but I can't get the caliper to seat on the one slide gromet (the top one). It is stuck in the all the way out possition.
I talked to a friend in parts and he said he can get me a replacement gromet asse. from a core, but I need to get the old one out first. He said there is a nut I have to get out to get the slide out, how do I get one of those things out? I can't even see into the hole to know what size socket to use. I can get a snap on 4mm in but it's a short socket and I don't have a 4mm deep. So I went and bought a craftsman deep 4 but it's too chubby to get down the hole. Any idea what size I need to get to that nut?
thanks in advance.
Old Apr 6, 2004 | 05:36 PM
Riceburner247's Avatar
Default Re: 94 Accord EX reaar brake problem (funkmd)
Hmm, pics would be nice.........
You aren't talking about the rear brake piston are you? If so, You turn it with a big philips screwdriver to get to go back in. If not, well, someone out there will learn something new.
Old Apr 6, 2004 | 05:39 PM
.bagged's Avatar
Default Re: 94 Accord EX reaar brake problem (riceburner247)
Its not a trombone son..just use a screwdriver and get that piston..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">
You aren't talking about the rear brake piston are you? If so, You turn it with a big philips screwdriver to get to go back in. If not, well, someone out there will learn something new.</TD></TR></TABLE>
Old Apr 6, 2004 | 05:45 PM
funkmd's Avatar
Default Re: 94 Accord EX reaar brake problem (baGged93aCcord)
the piston is in guys.
I'm refering to the "piston like floats" that the caliper assembly bolts into that is stationary around the rotor.
Old Apr 6, 2004 | 06:06 PM
funkmd's Avatar
pics
http://home.comcast.net/~funk/HP1000.jpg
http://home.comcast.net/~funk/HPIM0072.jpg
http://home.comcast.net/~funk/HPIM0073.jpg
Old Apr 7, 2004 | 12:47 AM
kittedaccord's Avatar
go get a manual,and look in the trobleshooting area,im from maryland too ,whats wrong with md?partner?Maryland representing!!!
Old Apr 7, 2004 | 08:54 AM
funkmd's Avatar
Default Re: 94 Accord EX reaar brake problem (kittedaccord)
yeah, I talked to a friend last night, he said we're going to have to torch it for a long time and then cracnk it out.
jakeCB7
Mar 20, 2010 07:35 PM
stock94ex
Mar 1, 2009 06:26 PM
roy_collins@hotmail.com
Sep 15, 2004 11:42 AM
RacerBowie
Jan 31, 2003 12:04 PM
