Hi/Low beam harness
I was trying to switch my bulbs out when I noticed that the harness in my lude had a two prong setup. Honda said that it should be a one prong setup which would make perfectly good sense since the bulbs I purchased were one prong. I bought my lude salvaged, so I am thinking that the previous owner switched out the harness for something else
. Honda quoted me $226 per side for the harness. **** that! I haven't started looking around down here, but so far there are no ludes in any junkyard locally that I can cut the harnesses off of. Can somebody help a brother out? Thanks.
It is only 1 prong that holds the bulb in. The bulb plugs into the white thing. I can't think of what its called, but you just pull the bulb out of that.
otakueric
Mar 9, 2004 07:43 PM
