Ls/vtec connecting rod torque: LS or GSR spec?
What torque spec should I use for the connecting rod torque. LS calls for 31 ft/lbs and the GSR was at least 10 ft/lbs higher due to high rpms i was assuming. I guess i should use GSR spec? What do you guys think?
Actually b18b rods are 23 lb-ft and b18c1 is 33 lb-ft and is not because of rpms, but because the b18c rod studs/nuts are bigger; 8mm vs. 9mm.
So if you are using ls rods then you torque to ls specs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">Actually b18b rods are 23 lb-ft and b18c1 is 33 lb-ft and is not because of rpms, but because the b18c rod studs/nuts are bigger; 8mm vs. 9mm.
So if you are using ls rods then you torque to ls specs</TD></TR></TABLE>
good job you beat me to it.
my computer sucks at doing stuff
Hello I building a ls vtec . B18b bottem end wit b18c head . I got arp connecting rod bolts (arp) . Wat would the torque specs????? Should I use ls or gsr torque specs??? Need help ASAP THX
boredracer408
Sep 24, 2008 03:36 PM
