need 87 civic Si Motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingrat »</TD></TR><TR><TD CLASS="quote">I need a 87 Si motor to rebuild for Kim's Car. It needs more power. Anyone in NOVA area have one? Also what can/should you do to these motors?
thanks,
Alex.</TD></TR></TABLE>
Try the classifieds here: http://www.redpepperracing.com/forums/
FYI, the 87 CRX SI engine is the same and will bolt in.
thanks,
From: boldly scornful of higher mental function, US
I have one. It's in Atlanta. .20 over and IT legal. The head might be spoken for, but otherwise it's all there. Most definitely would need you to pick it up, but let me know.
I have 4 Si heads.
1 or 2 cranks
I think all my blocks are the 4wd version, which are used to bolt up a stock 1st gen Integra gear box. BTW, I also have a Mugen 1-2 gear set for the 1st gen box which along with a 86 Prelude 3rd (which I also have) make an awesome track gear box. Also have a narrow but extra thick radiator.
Stock, Mugen 10-40 regrind, AT Eng and custom Crower Cams
(2) TWM ITB or DCOE intake manifolds, sorry I sold the DCOE Webers.
(1) custom UD single pulley to be used with Electromotive trigger wheel.
(1) Camshaft trigger wheel assembly
(1) custom 4-1 header (can't use stock fans and must use the above radiator)
1 or 2 cranks
I was going to suggest the same as rpr. Post a WTB on http://www.redpepperracing.com...rum=7
Also, if you are building an engine, you can use a non-Si block. The early 1.5 engines are plentiful.
I have a block I could spare, if you need.
As far as what you can do to the engine, check here
http://www.redpepperracing.com...um=15
