Rear alignment
Old Apr 6, 2004 | 08:23 AM
miedosoracing's Avatar
Default Rear alignment
I think my alignment is off in the rear. Who knows what this doof hit, I was lied to because he said it wasn't crashed, but it was. Anyways, hopefully the title is clear. I am still waiting for it. But the question is, when I go over a bump, the rear end wants to move sideways. always to the same side. Also, it looks maybe like the rear driver side is faced in a little. Can this be adjusted, or do I need to get new parts? Thanks
Old Apr 6, 2004 | 08:46 AM
brads94accord's Avatar
the only way to know if its off is to go get an alignment, they might have to do a sub frame shift. it sounds like its off though if it wants to go to one side.
Old Apr 6, 2004 | 11:08 AM
syclone's Avatar
Default Re: (brads94accord)
yes, get a full 4-wheel alignment.. they'll need to make sure the thrust angle is correct..
if it's aligned properly and it still shifts over bumps, it could be that your shocks are blown and the springs are just bouncing causing the wheel to skip to the side..
Old Apr 6, 2004 | 03:06 PM
pimpinhonda's Avatar
Default Re: (syclone)
could also have a broken belt in your tire . check that out
solo-x
98
Jan 29, 2014 06:25 AM
esoterEK..
Suspension & Brakes
Jul 29, 2008 01:26 PM
asmallsol
Apr 13, 2004 09:32 AM
SPiFF
Feb 7, 2004 04:49 PM
EricUSC
Jun 19, 2003 07:41 PM
