D15B2 Mini-Me Shopping list complete?
Old Apr 6, 2004 | 07:47 AM
Stoich's Avatar
Default D16Z6/D15B2 Mini-Me Shopping list complete?
Hey guys I have been reading the boards for a while now and have gotten some great info thanks: P
I am almost done (I think) gathering all the stuff I need for my d15b2 mini-me here is the list
D16Z6 SOHC Vtec head
D16Z6 dizzy
D16z6 intake manifold (with all sensors and fuel components)
OBD-0/OBD-1 harness
P28 ECU
4 wire o2 sensor
Inj resistor box
D16Y8 Head Gasket
D16Z6 Intake and exhaust gaskets
D16Z6 Timing Belt
Anything I have overlooked?
Now first order of business will be the DPFI to MPFI swap
In order to do this can I use the injector plugs from a Si harness with the Z6 injectors? or can i use the si injectors in the Z6 manifold?
Modified by Stoich at 2:36 PM 4/16/2004
Old Apr 6, 2004 | 10:01 AM
tgreaves's Avatar
Default Re: D15B2 Mini-Me Shopping list complete? (Stoich)
Injectors are interchangable.. If they are obd1 injectors you dont need the resistor box.. If they are obd0 then you do need it..
You dont use the SI harness, you modify your dx harness for mpfi..
Also let me know if you need a Z6 head, I have one for sale..
Old Apr 6, 2004 | 04:58 PM
Stoich's Avatar
Default Re: D15B2 Mini-Me Shopping list complete? (tgreaves)
So which should i use?
i am going to a crashed Si tomoro to pull the harness
do i need the whole thing or just the injectors clips?
since im doing Dual point to mulit wont i need the risitor box to step down the voltage for the 4 injectors?
Old Apr 6, 2004 | 05:21 PM
Jays91DXhatch's Avatar
Get the whole harness from the Si, but use only the clips for the injectors.
If you are staying with OBD-0 for now if you are only doing the MPFI swap first, then you will need the resistor box.
What I did when I did my B16 and switched to MPFI was to use the Si injector plugs and I kept the wires attached that went to the resistor box, I only cut the other wires and soldered them onto the DX harness. This worked really well and looked factory.
then when you switch to OBD1 you'll have to remove the box.
What kind of compression does the D15B2 and Z6 head yield?
Old Apr 6, 2004 | 05:27 PM
Stoich's Avatar
Default Re: D15B2 Mini-Me Shopping list complete? (Jays91DXhatch)
Since i am going to do the Obd1 conversion would i be better off using the obd1 Z6 injectors?
Modified by Stoich at 2:53 AM 4/7/2004
Old Apr 6, 2004 | 05:54 PM
Stoich's Avatar
TTT need some help im going to pull parts tomoro and i need to know what to get
Old Apr 6, 2004 | 06:40 PM
Redline130's Avatar
Since you will be using the P28 and converting to OBD1, just use the OBD1 injectors w/o the resistor box. And like it was mentioned, just use the connectors from the Si harness to convert your existing DX harness.
Old Apr 6, 2004 | 06:44 PM
chunker72's Avatar
Default Re: D15B2 Mini-Me Shopping list complete? (Redline130)
take pics when you do it, i was thinking of doing this but am new to imports so i want an idea of what im getting in to. V8s are so much easier lol.
Old Apr 7, 2004 | 02:04 AM
Stoich's Avatar
Default Re: D15B2 Mini-Me Shopping list complete? (chunker72)
Thanks redline
most of the writeups i have seen for the Dpfi to Mpfi use the Box and stay obd0
how do i split the wires to the injectors without the box?
Old Apr 7, 2004 | 04:44 AM
tgreaves's Avatar
Twist all 5 of them together and solder..
Old Apr 7, 2004 | 08:58 AM
1QWKCRX's Avatar
I've run my mini-me for the past 2 years with very few problems (well, after
the rebuild that is!)
Some very important things to remember:
1) REMOVE THE OIL JET IN THE A6 BLOCK!!!
2) Get all new head studs (Honda or ARP)
3) Replace your seals and gaskets
4) Replace your H20 pump as well!
Good luck!
N/A A6/Y8: 14.98 1/4 mile
130 whp / 114 wtq
Comp. 11:1
Old Apr 7, 2004 | 09:03 AM
Default Re: D15B2 Mini-Me Shopping list complete? (1QWKCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QWKCRX &raquo;</TD></TR><TR><TD CLASS="quote">I've run my mini-me for the past 2 years with very few problems (well, after
Good luck!
130 whp / 114 wtq
Comp. 11:1</TD></TR></TABLE>
That's the same HP and 10 more ft. lbs of torque then my B16.
Old Apr 8, 2004 | 01:33 AM
Stoich's Avatar
Thanks for all the replys guys
Can i use the risistor Box to wire all the injectors even if im going to convert to obd1?
i was planning on using this write up to do the MPFI swap
http://hybrid2.honda-perf.org/tech/4gdxtozc.html
Old Apr 8, 2004 | 07:00 AM
jlicrx's Avatar
you will also need fuel line from filter to fuel rail from Si or HF
Old Apr 16, 2004 | 05:38 AM
Stoich's Avatar
Default Re: D15B2 Mini-Me Shopping list complete? (jlicrx)
Well I almost have everything I need to finish up this project
So far I have
D16Z6 Cyn Head
D16Z6 Intake Mani
D16Z6 Dizzy
D16Z6 Harness (for all the misc plugs I might need)
4 wire o2 sensor
P28 ECU and Obd0/Obd1 Conversion harness
D16Y8 Head Gasket
D16Z6 timing belt & tensioner
D15B7 water pump & thermostat
Intake & Exhaust mani gaskets
Valve cover gasket set
The swap will go down next weekend
Ill post pics when im done
PS: feel free to add anything I may have overlooked
gnccracer20
Feb 16, 2009 05:34 PM
SJcivic
May 3, 2007 09:28 PM
memorybox
Jul 4, 2006 10:06 AM
kapoosh valve
Mar 27, 2005 05:00 PM
SIsohcvtec
15
Sep 11, 2004 05:30 AM
