Vibration in the steering wheel, braking at 60+ miles... help
Hi guys
this is my first posting here
I got a 97 Accord SE, very rare ones
the problem is when im driving in the freeway or street, at 60 miles or over, and i brake the steering starts to vibrate, in a medium instesity then a litte harder.
do you guys think, i might need to change or shape my brake disc?
or something else?
helps will be good
Thanks
ZERO
or something else?
helps will be good
Thanks
ZERO
get your rotors machined or replace them, they're uneven and when you hit the brake it causes the steering wheel to wobble.
It may not always be the rotors, My car also has the same problem but the rotors are perfect. The reason may be a weak wheel bearing. You can get that checked at a workshop.
first of i agree its 99% the rotors but its not a good idea to get them turned...its better to have honda rotors replaced rather than "repaired"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiKWiD*BaNaNaZ »</TD></TR><TR><TD CLASS="quote">its better to have honda rotors replaced rather than "repaired"</TD></TR></TABLE>
LOL my guess is you know nothing at all.
<-----Honda Technician
I think you should wait and watch a bit, coz my problem disappeared on its own after a couple of months. Get the rotors checked at sears, they do a complete brake inspection for 15 bucks (they check for rotor warping, they tell you if you can machine the rotors, which is possible only if the thickness of the rotor is greater than the minimum suggested by honda. see what they say, and proceed from there. Unless you have unlimited money of course
well, money is not mainly the most i have... hehe
so ill follow ur tip
thanks everyone, you all are gonna see me here more often
zero
zero
99.9% chance ur rotors are NOT warped, most likely its residue from the pads that sticks on the surface of the rotor unevenly, read up on http://www.accordinglydone.com its got a lot of info
Michael60
Apr 25, 2003 11:26 AM
