should I change my brake fluid with 22,200?
Old Apr 5, 2004 | 10:40 PM
PY 01-0972's Avatar
Default should I change my brake fluid with 22,200?
The manual says every three years has anyone changed theres or should I wait tell 36000? thanks
Old Apr 5, 2004 | 11:12 PM
B2FiNiTY's Avatar
Default Re: should I change my brake fluid with 22,200? (PY 01-0972)
Depending on how dark it is, I would change it.
I personally would change it.
Old Apr 5, 2004 | 11:15 PM
kepani's Avatar
it would never hurt to change any fluids before recommended intervals. especially if you've brought your car to a track event - which takes a toll on the braking system. even the fact that most itr owners will run their car harder than the avg. driver will warrant a more frequent change.
you should change your brake fluid at least once a year. it's not too hard and not expensive at all.
kepani
Old Apr 6, 2004 | 03:32 AM
.RJ's Avatar
.RJ
Default Re: should I change my brake fluid with 22,200? (kepani)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kepani &raquo;</TD></TR><TR><TD CLASS="quote">you should change your brake fluid at least once a year.</TD></TR></TABLE>
If you're just street driving, the OE honda stuff is good.
For track events, Motul RBF600 is liquid gold.
Old Apr 6, 2004 | 05:55 AM
Flux's Avatar
Default Re: should I change my brake fluid with 22,200? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
For track events, Motul RBF600 is liquid gold.</TD></TR></TABLE>
Just a comment about the Motul 600 fluid - I was buying some pads from the guys at Cobalt Friction so I thought I'd buy some of the Motul 600 from them as well for an upcoming track event. They told me that they recommend the Motul 600 be only used in dedicated race cars and that the Motul 5.1 (which they do not sell) that I am currently using will be just as good for a track day and I should stick with it. Said it was better that ATE Super Blue as well.... I found that interesting.
Old Apr 6, 2004 | 06:00 AM
.RJ's Avatar
.RJ
Default Re: should I change my brake fluid with 22,200? (Flux)
My car is still a street car.... I am using it with no ill effects at all.
I have almost 3,000 street miles miles, 10 track days with over 1,000 track miles on the fluid now, and it did not boil at CMP - and i was certainly not nice to the brakes there (glazed my XP8's).
So you guys can save money up front on ATE superblue and bleed it all the time, or use a better fluid and flush it twice a year. Less effort and less money spent in the long run. I really dont know where they got their info that you cant use Motul 600 on a street/track car.
Old Apr 6, 2004 | 06:15 AM
Flux's Avatar
I wasn't saying the Motul 600 is a bad fluid to use - I did find it interesting that Cobalt, who we all regard as Brake gods around here, suggested I not use it.
Old Apr 6, 2004 | 06:16 AM
.RJ's Avatar
.RJ
Well I can say with reasonable certainty that information is incorrect
Old Apr 6, 2004 | 06:22 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">
They told me that they recommend the Motul 600 be only used in dedicated race cars and that the Motul 5.1 (which they do not sell) that I am currently using will be just as good for a track day and I should stick with it. Said it was better that ATE Super Blue as well.... I found that interesting.</TD></TR></TABLE>
did they say why it should only be used in race cars?
Old Apr 6, 2004 | 09:44 AM
uNF$@#!'s Avatar
Default Re: should I change my brake fluid with 22,200? (mstewar)
is the motul 600 considered a DOT 5.0 brake fluid?
dot 5 = corrosive
dot 5.1 = non corrosive
Old Apr 6, 2004 | 09:47 AM
.RJ's Avatar
.RJ
Default Re: should I change my brake fluid with 22,200? (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">is the motul 600 considered a DOT 5.0 brake fluid?
DOT4
http://www.hmsmotorsport.com/s...d=cat
Old Apr 6, 2004 | 09:50 AM
Solracer's Avatar
DOT4
http://www.hmsmotorsport.com/s...d=cat</TD></TR></TABLE>
I did not realize that was Motul 600 was DOT 4 I going to have to get some of that...
Old Apr 6, 2004 | 09:56 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">My car is still a street car.... I am using it with no ill effects at all.</TD></TR></TABLE>
I have also been using Motul RBF600 in my cars for years with no problems
Nice Fit
Honda Fit
Mar 5, 2009 06:23 PM
kornerk12
Dec 30, 2005 12:53 PM
slow91crx
12
May 17, 2005 05:38 PM
itr561
Jun 17, 2004 01:59 PM
Mike B
17
May 6, 2002 03:20 PM
