Oil pressure timing swich ?????
Old Apr 5, 2004 | 10:07 PM
98rotax's Avatar
Default OIL PRESURE SWITCH NO VTEC ?????
Hi!
I brought this car 1 mounht ago and it seems to me that the vtech do not worck properly! Each time that I rev the engine up 4500 rpm the check engine light come on.
The check engine code is 22.
-I changed the Oil pressure timing swich for a new one from honda
-I have inspect and test the spool valve selenoild and filter ( it is clicking and it have a 15 to 30 resestance)
I read tha I could create a jumper out of a piece of wire and run it from D6 to A4, but my check engine light will light anain ( I supose I'm just paching the trouble?)
I checked almost everything from Honda Civic Factory Service Manual (92-95) about Oil pressure timing swich and the spool valve (I can not check the ecu or if the connections are good between connection and the ecu)
I 'm thincking that I may have not enought oil pressure maybe my oil pump is not good?
I need help
Thancks
Steve c
watercross9@hotmail.com
Modified by 98rotax at 6:03 PM 4/6/2004
Old Apr 6, 2004 | 07:19 AM
mmuller's Avatar
Mad Scientist
Default Re: Oil pressure timing swich ????? (98rotax)
chech oil pressure, vtec needs 50psi +
jchrm80
Apr 5, 2007 01:22 PM
chump2825
Dec 25, 2006 10:24 AM
captainjdog
Jan 12, 2006 08:03 AM
PatrickGSR94
Dec 19, 2004 07:45 PM
jimburroughs
Apr 24, 2002 11:27 AM
