fog light switch question........
Old Apr 5, 2004 | 07:01 PM
Kyo Babic's Avatar
Default fog light switch question........
is it possible for the light itself inside the switch be able to burn out? i recently put some 89 prlude foglights in my 91 civic using a walmart harness etc, everything works fine, but the switch i got (oem 89-90 accord switch i think) from the junkers , the light on it doesnt light up....so is it possible to repalce the light if so how do i take the switch apart, or should i even bother with it?
Old Apr 5, 2004 | 07:13 PM
Syner-G-Racing LLC's Avatar
Default Re: fog light switch question........ (Kyo Babic)
bro, some of those switches are molded together some are pieced together...go to radio shack and buy you a new switch for $1.50. if it still doesnt light up check the voltage to the switch.
Old Apr 5, 2004 | 07:18 PM
gumbii's Avatar
hmm... those switches sometimes have like a little cut out round hole with a green thing with a slot in it...
you need a small screw driver, one for some glasses... just twist it and it should pop out with a small light bulb in it... well, thats how my S2000 engine button... but if it's like my sol's buttons... you could take it apart... there are like four clips that you need to pry apart... and there should be like two of those bulb twist things...
92b16si
Honda Civic (2001 - 2005)
Mar 27, 2014 04:45 PM
93H22APrelude
Feb 9, 2005 08:46 AM
beaterman
Oct 29, 2003 11:14 PM
