what are your rpm at?
Old Apr 5, 2004 | 05:43 PM
megotvtec's Avatar
Default what are your rpm at?
when you type-r guys are racing and you shift at 8400 what do your rpm's drop down to?for example my gsr shifts at 8400 and drops to 6000 for the next gear.
and also how fast are you going when your sitting at 4500 in 5th?
Old Apr 5, 2004 | 06:04 PM
1GreyTeg's Avatar
Default Re: what are your rpm at? (megotvtec)
Play till your hearts content:
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
http://reverendsgarage.net/ind...r.php
Old Apr 5, 2004 | 06:07 PM
baonest's Avatar
Default Re: what are your rpm at? (1GreyTeg)
i like to hit 5 digits when i shift
Old Apr 5, 2004 | 06:09 PM
ek4b18c_r's Avatar
at 4500 in 5th i am around 80mph, i shift at 8600 and it goes to around 5700-5800
Old Apr 5, 2004 | 07:22 PM
megotvtec's Avatar
Default Re: what are your rpm at? (ek4b18c_r)
ek4b18c_r: really cause when i shift i goes down to 6000 so how does your tranny have shorter gear ratio?? i thought it would go to like 6500-7000
Old Apr 5, 2004 | 08:19 PM
Kendall's Avatar
My ITR does 90 mph at only 3100 rpms. I have to shift at 5500 at the most because the fuel cut is at 5900.
Old Apr 5, 2004 | 08:26 PM
vtec.dc2's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">My ITR does 90 mph at only 3100 rpms. I have to shift at 5500 at the most because the fuel cut is at 5900.</TD></TR></TABLE>
lol.. but what about the VTECH?
Old Apr 5, 2004 | 08:32 PM
1GreyTeg's Avatar
Default Re: (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
lol.. but what about the VTECH?</TD></TR></TABLE>
I'm doin 94 mph in 5th gear at VeeTech yO.
Old Apr 5, 2004 | 08:41 PM
uNF$@#!'s Avatar
Default Re: (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
I'm doin 94 mph in 5th gear at VeeTech yO.</TD></TR></TABLE>
and you redline at 110mph yo
Old Apr 5, 2004 | 08:44 PM
1GreyTeg's Avatar
Default Re: (Soup ****)
In 4th at 8k yepper.
5th at fuel cut is 139mph,
but I thought we covered this all before?
Old Apr 5, 2004 | 08:48 PM
ek4b18c_r's Avatar
i am not sure what rpm's i am at but when i shift at 8600 and step on the gas it takes about a second before vtec engages, so know its not at 6000. give me a day and i will let u know for sure
Old Apr 5, 2004 | 09:09 PM
megotvtec's Avatar
sounds good thanks.
Old Apr 5, 2004 | 09:15 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by megotvtec &raquo;</TD></TR><TR><TD CLASS="quote">sounds good thanks.</TD></TR></TABLE>
Why don't you just use the gearing calculators posted above?
That would make alot more sense than the other guy waiting till tomorrow and posting what he remembers his inaccurate tach and speedo indicating.
Old Apr 5, 2004 | 09:30 PM
megotvtec's Avatar
last question, what has shorter gears. the b16 or the b18c type-r tranny?
Old Apr 5, 2004 | 09:40 PM
vtec.dc2's Avatar
http://www.a-t-s-usa.com/ats-p...shtml
Old Apr 5, 2004 | 09:45 PM
megotvtec's Avatar
Default Re: what are your rpm at? (vtec.dc2)
thanx vtecdc2 know can anyone tell me as to where i can purchase a itr type-r tranny w/ lsd??
Old Apr 5, 2004 | 09:51 PM
vtec.dc2's Avatar
https://honda-tech.com/zeroforum?id=10 just select the seller wisely
Old Apr 5, 2004 | 10:44 PM
CDN Yellow ITR's Avatar
i shift at 8500rpm-8600rpm, the motor is still in vtec when i get into 2nd. not sure if this is ne use to you but meh. my .2 cents.
Old Apr 7, 2004 | 09:19 PM
ek4b18c_r's Avatar
okay i was trippin when i said when i shift at 8600 it drops to 5800, 1st to 2nd i shift at 8600 and it drops to 6100.
Old Apr 9, 2004 | 12:53 PM
redline23's Avatar
i shift at 8400 and it drops to about 5800 cause i'm still in vtec. Thats first gear though. b16 tranny and itr are the same gear ratio. 98 spec r tranny has the 4.785 final drive . at 4500 rpm in 5th is about 90.
Old Apr 9, 2004 | 02:13 PM
RiCE On IcE 2's Avatar
when you shift at red you should still be in vtec in the next gear...
Old Apr 9, 2004 | 02:40 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: what are your rpm at? (baonest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">i like to hit 5 digits when i shift</TD></TR></TABLE>
Ten Grand Deep
IDB Racing
Old Apr 10, 2004 | 07:12 PM
megotvtec's Avatar
Default Re: what are your rpm at? (v-attack)
im confused i though shorter gearing meant like if you shift at 8200 it will drop to like 7000
Old Apr 12, 2004 | 06:05 PM
iskendi's Avatar
Hey,
I have a 92 integra gsr. It seems like my rpms run high, at 60mph my rpm is 3500rpm at 70mph its 4000rpm. Is this pretty normal or is it high.
Old Apr 13, 2004 | 11:55 AM
megotvtec's Avatar
Default Re: what are your rpm at? (iskendi)
thats normal. my rpms are right at 4000 at 75mph and 4500 at 92mph
