A few more motor questions.....
Old Apr 5, 2004 | 05:30 PM
Lees_89_CRX_HF's Avatar
Default A few more motor questions.....
I have an 89 Crx HF, if i bought a wrecked 94 civic with v-tech would the v-tech ecu from the civic work in the crx? Does anyone know the correct name for the 94 civic motor? (d15, d16 like that kind of name.....)
Old Apr 5, 2004 | 05:35 PM
cbrodac0424's Avatar
Default Re: A few more motor questions..... (Lees_89_CRX_HF)
I believe that it is a d series motor best bet would be to look at the motor and look at the stamp on it and it will tell u should be a d-15
Old Apr 5, 2004 | 06:10 PM
Charlie Moua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lees_89_CRX_HF &raquo;</TD></TR><TR><TD CLASS="quote">I have an 89 Crx HF, if i bought a wrecked 94 civic with v-tech would the v-tech ecu from the civic work in the crx? Does anyone know the correct name for the 94 civic motor? (d15, d16 like that kind of name.....) </TD></TR></TABLE>
well it's vtec not vtech
that motor is a d16z6 (92-95 sohc vtec)
the ecu that came with that motor was the P28
If I were you i would do it the right way and convert to obd1.
you should be able to use your stock axles and tranny. however you will need the 92-95 civic D16 driver side mount.
UltraMax123
Dec 23, 2010 03:21 AM
93formula
Dec 5, 2008 02:14 PM
blakezilla06
Dec 15, 2005 06:45 PM
LS7
Feb 17, 2004 09:29 AM
