I need help with a motor....
Old Apr 5, 2004 | 05:05 PM
Lees_89_CRX_HF's Avatar
Default I need help with a motor....
Can someone tell me if a 1994 Honda Civic 1.6L SOHC V-Tech engine will work in a CRX? If it will work, what all will I need to have to make it work? Thanks
Old Apr 5, 2004 | 05:16 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
It will fit well. You won't need mounts, but you will need to convert your car to OBD1. If yur CRX is a DX then you'll have to convert it to Multi Port Injection. Also, you'll need the VTEC ECU, and 4 wires to hook up. It sounds harder than it really is. I promise.
Old Apr 5, 2004 | 05:19 PM
speed_racer012's Avatar
Default Re: (VashTheStampede)
for the mount you will have to take the WHOLE mount off of your stock motor. both the bracket on the block and the mount.
Old Apr 5, 2004 | 05:21 PM
airikkCRX's Avatar
Default Re: I need help with a motor.... (Lees_89_CRX_HF)
or you could just convert the motor to obdo and get a computer for the vtec
Rrm101
Mar 19, 2009 10:24 AM
regal1975
Jan 4, 2008 05:00 PM
nicholixzavier
Oct 24, 2007 04:32 PM
efjuice
Oct 24, 2003 02:36 AM
