i need an answer
Old Apr 5, 2004 | 03:29 PM
Live_Love_Burn_Die's Avatar
Default i need an answer
hey,
will a ZC dohc head bolt on to a D16A6 block...........cause there is a guy i can get the head from for like $150 i was wondering.........and i also wanted to know if it will make a noticeable difference. and also what timing belt would i use for it...i need to know asap.................thank you
jason
Old Apr 5, 2004 | 04:21 PM
Default Re: i need an answer (emanon5k)
please help..........come on
Old Apr 5, 2004 | 04:30 PM
crxgator's Avatar
not worth it to even try...put it this way, you "cant"...
Old Apr 5, 2004 | 04:33 PM
Curtis2kul's Avatar
Default Re: i need an answer (crxgator)
why can't you? i always heard a D Head can fit a D bottom, same for b, etc.
Old Apr 5, 2004 | 04:36 PM
anyone else have an opinion.....cause i would really like to try to do it, but what all would i have to do to get it to work
Old Apr 5, 2004 | 05:57 PM
bump
Old Apr 5, 2004 | 06:23 PM
riceburners1's Avatar
DOHC on SOHC......figure it out yet............................NO!
Old Apr 5, 2004 | 06:26 PM
EF9Dreams's Avatar
technically its possible..... a SOHC ZC motors head might be able to bolt up to a D series but a DOHC can't.....
Old Apr 5, 2004 | 06:31 PM
krazie1's Avatar
BANNED
Default Re: i need an answer (EF9Dreams)
correcto mondo!!!!
this ain't like a ls/vtec set up
this both have to of came from a sort of same set up
like posted before
twin cam to twin cam
single to single
but even some of the twin cams we can't like the old lude motors they were B series
Old Apr 5, 2004 | 06:45 PM
boostn420's Avatar
Default Re: i need an answer (krazie1)
The head fits just fine, you'd need the intake manifold for it to though because the sohc ones have a different bolt pattern.
Now let me say this. Its not worth it, that head sucks, if you put an obd2 non vtec head on instead, it should cost the same, you use your stock manifolds, you keep your stock dizzy and dont have to rewuire sensors, but most importantly is has a much smaller combustion chamber that will raise compression and it has 1mm bigger valves. That car would be much faster with that head than it would be with some old *** probably warped dohc head.
Old Apr 5, 2004 | 08:32 PM
Default Re: i need an answer (boostn420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn420 &raquo;</TD></TR><TR><TD CLASS="quote">The head fits just fine, you'd need the intake manifold for it to though because the sohc ones have a different bolt pattern.
Now let me say this. Its not worth it, that head sucks, if you put an obd2 non vtec head on instead, it should cost the same, you use your stock manifolds, you keep your stock dizzy and dont have to rewuire sensors, but most importantly is has a much smaller combustion chamber that will raise compression and it has 1mm bigger valves. That car would be much faster with that head than it would be with some old *** probably warped dohc head.</TD></TR></TABLE>
thanks man...........what kind of head is obd2? and i would have to get a new ecu and all right
icanbrkurhrt
Jun 18, 2009 05:59 AM
remoer
Jul 10, 2007 07:42 AM
Y_my_91
Jun 4, 2006 07:33 PM
CivicRaping
Mar 8, 2005 11:13 PM
TurbodCX
Apr 18, 2002 10:39 AM
