Pics of the 11.75" Fastbrakes setup..yummy
Old Oct 25, 2001 | 01:05 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Pics of the 11.75" Fastbrakes setup..yummy
I told brian i would post the setup..looks nice on those C8 rims.
[Modified by Rguy, 2:06 PM 10/25/2001]
Old Oct 25, 2001 | 01:16 PM
Hybrid ctr's Avatar
Default Re: Pics of the 11.75" Fastbrakes setup..yummy (Rguy)
11.75" is how many ???mm
Old Oct 25, 2001 | 01:23 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: Pics of the 11.75" Fastbrakes setup..yummy (Hybrid ctr)
if my math is wrong i apologize, but i believe its 298.45mm ..taking into account there are 32 inches in a meter.
[Modified by Rguy, 2:28 PM 10/25/2001]
Old Oct 25, 2001 | 01:25 PM
HX_Guy's Avatar
11.75" = 298.45mm
1" = 2.54cm
1cm = 10mm
Old Oct 25, 2001 | 01:26 PM
HX_Guy's Avatar
Default Re: Pics of the 11.75" Fastbrakes setup..yummy (HX_Guy)
BTW those look freaking sweet! I love then the brakes fill up the whole wheel
Old Oct 25, 2001 | 01:50 PM
fastbrakes's Avatar
The calipers have about 2-3mm clearance at the ends and top, so wheel weights will have to be placed away from the area where the caliper will be. It's a very tight fit...
Old Oct 25, 2001 | 01:53 PM
ryan12321's Avatar
Default Re: Pics of the 11.75" Fastbrakes setup..yummy (fastbrakes)
what size wheel is that?
Old Oct 25, 2001 | 03:09 PM
RacingE_Teg's Avatar
Default Re: Pics of the 11.75" Fastbrakes setup..yummy (ryan12321)
Did you also get the rear brake upgrade? If so, can I see some pics.
Thanks
Old Oct 26, 2001 | 07:38 AM
fastbrakes's Avatar
It's a 15 x 6.5 Rota +38 offset
Old Oct 26, 2001 | 07:42 AM
fastbrakes's Avatar
Default Re: Pics of the 11.75" Fastbrakes setup..yummy (RacingE_Teg)
I've got the prototype 11.4 2 piece rear upgrade, but that won't fit the ITR unless you use the standard Teg rear calipers. Simple swap.
I will be making a stock ITR size (10.25") 2 piece rear upgrade if anyone wants it.
Either kit will save about 3-4 lbs per wheel.
Old Oct 26, 2001 | 08:08 AM
chad's Avatar
Moderator
that looks nice....i need just big front brakes up front soon!
Old Oct 26, 2001 | 08:21 AM
HapaHaole's Avatar
Default Re: Pics of the 11.75" Fastbrakes setup..yummy (chad)
is that the long lost CoolTech rotor!
Old Oct 26, 2001 | 10:24 AM
Katman's Avatar
...have those been test-fitted under a 15" EVO/Spoon wheel?
preferrably 15x6.5 +45 offset...if not..I'll glady be test dummy to try some on my EG
Old Oct 26, 2001 | 01:35 PM
fastbrakes's Avatar
Default Re: Pics of the 11.75" Fastbrakes setup..yummy (Katman)
They should fit Kman, place your order now...
Old Oct 26, 2001 | 03:39 PM
Katman's Avatar
heheh ok!
Old Oct 26, 2001 | 04:18 PM
vtecvoodoo's Avatar
Future Texas Boy
Rokken like Dokken! Luv mine
hatchback_al
12
Dec 16, 2004 05:18 PM
Neukin
Mar 29, 2003 04:35 PM
mackymcg
Feb 21, 2003 05:58 PM
CunninLynguist
Nov 20, 2002 01:06 AM
