Replacing Busings
Old Apr 5, 2004 | 06:42 AM
CRexcellence's Avatar
New User
Default Replacing Bushings
I recently got the parts needed for a rear disc swap from a 90 teg. After taking a good look at the trailing arm from the teg I see that the large bushing (that has the metal bracket <U>through</U> it) that gets bolted up on the frame look pretty beat. I think I might try to replace this on both sides. So here are a few questions and feel free to give me your recommendation?
Should I go aftermarket with ES or order new OEM ones?
If I go with ES where is the best place to order them?
Does ES make this replacement bushing?
Old Apr 5, 2004 | 07:42 AM
spaceman's Avatar
Default Re: Replacing Bushings (CRexcellence)
es is good make sure you get the correct bushings for that part...go to their website or something.
Old Apr 5, 2004 | 08:28 AM
snapcase318's Avatar
I'm in the same boat, I've heard that the es is alot easier as it's 2 pieces and alot easier to install than the factory one. Summit has the 90-93 bushings for the rear trailing arms in stock but you have to call-it's noit on their website. I believe they were $26. I'm not sure how they work though since the stock piece actually attches to the metal piece.
Old Apr 5, 2004 | 11:11 AM
New User
Default Re: Replacing Bushings (snapcase318)
Thanks for the help guys. Is there a name for the bushing on the trailing arm, or would I have to describe it to someone at Summit racing? Was this a whole trailing arm bushing kit?
Old Apr 5, 2004 | 01:27 PM
Just tell them you need the rear trailing arm bushings for a 90-93 Integra, it's the left+right side. I just ordered mine a few minutes ago and they were $30 at Summit. There's only one bushing per trailing arm so I guess this is what you mean by complete kit.
Old Apr 5, 2004 | 01:28 PM
BTW- make sure you do infact have trailing arms from a Teg. as the CRX and Integra's are different part numbers.
Old Apr 5, 2004 | 04:00 PM
New User
Yeah I definately have the teg trailing arm. Thanks for the help I think I will try Summit
aimbot
Apr 22, 2011 06:30 AM
NotFastEnuff
Nov 14, 2010 09:46 AM
fonkernuckle
Jul 3, 2009 08:43 PM
lucas569
May 1, 2003 07:18 AM
johnzm
Nov 16, 2002 04:11 PM
