b18a or b ? ( turbo )
i might get an ls b18a or a ( B ). im not sure what one yet, maybe you can tell me what one is the best to with . i have a t/3 and a vannuys tubular manifld bov, internal waste gate and 7.5 actuator. conquest intercooler vortec fmu 12/1 diaphram. walbro 255 and highflow fuel filter 440's injectors no cat
and an ls computer. i want to keep stock internals and boost 10 psi is this possiable and if i do go with this what kind of times will exspect on 15x6 gsr wheels street tire s and takicos oh ya stage 2 clutch and ls tranny?? please help me out i need oppions.. thanks for keepen it real ... this is all going in an 89 crx si
I'd get the B18B if I were choosing, just because they are generally going to have less mileage on them, meaning that they will be in better shape for boosting.
b18b has better cams. everythying else is the same. oh and that's a bit much fuel. you can sell the FMU for about $100 and buy an SMC500 from someone on here to control those injectors and you should be fine.
...or you could do what i'm doing and get an A block with a B block. I'm rebuilding both and setting up for a turbo. Plus there a lot less coverting you have to do. If you do get the B18b than get a B18a distributor and ECU because you wont have to rewire provided you have an Si.
Thats my 2 cents
Thats my 2 cents
B would be newer but A would be cheaper, I bought 2 b18a longblocks for 400 bucks, one of them ive been boosting for a while and I ran half assed fuel maps on it and it held like a champ, I did a compression check and it was at 210 all across. Just find whatever block has is in the best condition, it all depends on the person who had the motor before and how they took care of it. Either one will hold up fine to boost tho.
yeah i know the b18 b's are cheaper. i might just go with one, and have more money to build a bottom end. as far as my set up would be, i could use some help
my biggest issue is reliability.i had a 95 gsr and i had the t/3 on it. it didnt last very long before i noticed oil consumption. before i had a chance to rebuild it it got stollen. but i still have the t/3 and manifold.
what would be a decent fuel setup? 10 lb boost
