HELP ME READ THIS
Old Apr 4, 2004 | 08:16 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default HELP ME READ THIS
Sunday the 28th the timing belt on my crx with a dohc zc fail of the cam gears so today monday the 4th i put on a new timing belt i put all the stuff back on the car and all my tools up i was gonna shut the hood when i saw i was a little low on water so i put some in the ?resavar? i dont know how to spell that and then i went to top off the rateater as i poured water in a hear it pouring out i looked and it coming from some where around my water pump.
What could i have done? I didnt lay a hand on the pump.
could it still run ok like this?....it only leacks when the top is off.
or could the fact that it is jacked up really high make this happen cuz the tilt of the car?
Old Apr 4, 2004 | 08:34 PM
crxzcracer's Avatar
Default Re: HELP ME READ THIS (crxzcracer)
bump
Old Apr 4, 2004 | 08:51 PM
Dropped2k2Civic's Avatar
you should have replaced the pump if you did the belt just a normail thing to do. But if the pump leaks that means its bad usually.
Old Apr 4, 2004 | 08:58 PM
T-Mo's Avatar
'reservoir' and 'radiator'. Sorry I can't help you. Maybe you shouldve at least changed the waterpump and gasket. It costs about $25-30 new. I work PT @ Advance and my bf works PT @ Autozone
Old Apr 5, 2004 | 06:51 AM
crxzcracer's Avatar
The water pump look new so i thought it would be fine is there any thing that could have happen other than that? or are looks just desevnig
Genesis777
Jun 13, 2017 06:40 AM
JdM_RACeR07
Dec 7, 2006 10:32 PM
spluvs2install
Aug 26, 2006 07:40 PM
snoop_bealybob
Mar 26, 2003 06:04 PM
Fooman
Oct 25, 2001 02:47 PM
