Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Suggestions to removing the tar left behind from sound deadening
Old Apr 4, 2004 | 07:32 PM
aesthetics82's Avatar
Default Suggestions to removing the tar left behind from sound deadening
I am currently trying to remove all the tar that was left over after removing the sound deadening. I used a sticker remover and that worked to remove the thin layers of left over residue but there are still thicker little pieces of the tar left over. What products will remove the rest? Can i use a grinder or anything to remove the rest or will that leave the exposed metal and have a chance to rust. I wanna clean up the inside as much as possible. thanks for the help.
-RJ
Old Apr 4, 2004 | 07:41 PM
hondahans's Avatar
Default Re: Suggestions to removing the tar left behind from sound deadening (aesthetics82)
After removing the chunks, I used a heat gun and a bunch of old towels/cloth to wipe it away. It's messy, but easily cleans right up. be careful though, hot tar sucks.
Old Apr 4, 2004 | 07:43 PM
bdb's Avatar
bdb
Default Re: Suggestions to removing the tar left behind from sound deadening (hondahans)
Goo Gone and some stainless steel wool to scrub off the remaining residue. Lots of work...
Old Apr 4, 2004 | 07:50 PM
SicNA94TegGsR's Avatar
Swollen Member
A wire brush attached to a drill...and some thinner...dont forget your mask
Old Apr 4, 2004 | 08:34 PM
shakedown94's Avatar
get paint thinner from parts store ans cloth type papertowels. and alot of elbow grease.
Old Apr 4, 2004 | 08:55 PM
thawley's Avatar
Default Re: Suggestions to removing the tar left behind from sound deadening (shakedown94)
Heat gun and a putty knife for the thick stuff. Then paint thinner and paper towels for the thin residue. Careful with those wet paper towels; it really sucks when they spontaneously combust in your trash can...
Baby oil or WD-40 will get it off your hands better than solvent. Have a six pack near by and something good on the radio. You'll be there a while.
Thawley
Old Apr 5, 2004 | 02:56 AM
jc836's Avatar
Been there and used a simple Hyde putty knife and a hammer. The knife has a beveled edge and will help remove the stuff with minimal damage to the paint. You will need solvents afterward to get the rest off. We used a PPG product that is similar to Prep Sol (Dupont). There are those that use Dry Ice-it will work nicely. I did find that a heat gun works, but can actually slow the removal and is messier. A mask and beverages are not a bad idea-it will take a good bit of time.
Old Apr 5, 2004 | 08:34 AM
Default Re: Suggestions to removing the tar left behind from sound deadening (jc836)
thanks for all the replys. i heard somewhere that thinners are not good products to use because they are flamable and even though you wipe off the thinner there is still gonna be some left on the floor of the car. is this true? after the tar is gone, is there a primer or something that i can use to put all over the floor? i wanna make the interior nicer looking but without having to pay too much or take it to a place to get it painted. i wanna do all the work myself.
Old Apr 5, 2004 | 09:12 AM
Lo-Buck EF's Avatar
well, ur from cali, so this wont work for you. but i helped a friend do his car and we did it in jan-feb months when it was 12 degrees here (NY). so i just hit it with a hammer to crack it and chip it out with a screwdriver. came right out and often in large peice with the tar. but thats only in quite cold temps
-spenc
Old Apr 5, 2004 | 10:00 AM
INTEGRAMIKE's Avatar
Default Re: Suggestions to removing the tar left behind from sound deadening (Lo-Buck EF)
I did it in when it was cold out too. Use dry ice to freeze it then it chips right off no problem. Set a towel over it for fifteen min. Then move the ice and chip up the area while you freeze another part. If you do it this way it only leaves a little bit of cleaning afterward.
Old Apr 5, 2004 | 10:01 AM
rickpeak's Avatar
lighter fluid works to remove any remaining residue
Old Apr 5, 2004 | 10:05 AM
Greyout's Avatar
Default Re: Suggestions to removing the tar left behind from sound deadening (rickpeak)
anyone ever tried to use some sort or aircraft paint stripper for that yellow-boiling acid stuff from home depot?
Old Apr 7, 2004 | 03:45 PM
Default Re: Suggestions to removing the tar left behind from sound deadening (Greyout)
i already have the sound deadening out, i just want to get rid of the residue left. i heard that using a flammable liquid to remove the residue is dangerous. is this true? also, there is orange puddy like stuff on some parts of the car where the sound deadening used to be. can i remove that as well?
Old Apr 8, 2004 | 07:12 AM
bdb's Avatar
bdb
You can try those non-toxic removers and stuff, but they *probably* won't do the trick as fast as a more harmful, toxic, and flamable solvent.
I'm using Goo Gone on the remaining tar residue and I think I'm in the same boat as you cause once I remove it all I was planning on painting the interior a nice durable battleship gray.
Before you paint though you use an alcohol to remove all the remaining solvent and/or grease residue. Then I think you'll be in good shape to paint.
Old Apr 8, 2004 | 08:10 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rickpeak &raquo;</TD></TR><TR><TD CLASS="quote">lighter fluid works to remove any remaining residue</TD></TR></TABLE>
:FIRE: hehe, I'm guessing you meant just as a solvent
Old Apr 10, 2004 | 09:24 PM
VX's Avatar
VX
Default Re: Suggestions to removing the tar left behind from sound deadening (splitime)
I used a paintscraper and a rag with this:
My how-to: https://honda-tech.com/zerothread?id=525936
Old Apr 10, 2004 | 09:38 PM
spirit R
Guest
Posts: n/a
Default Re: Suggestions to removing the tar left behind from sound deadening (VX)
I use engine cleaner
You spray it thick and then drag a rag through it a few times the best part is just spray it on and wipe it up a few times and your done
Then I surface prep with 3m liquid sandpaper
Old Apr 18, 2004 | 02:14 PM
does anyone know if you can remove the orange sticky tar like stuff? it seems like it's there holding the seams of the floor together.
Old Apr 18, 2004 | 04:26 PM
ajjohnsonnc1's Avatar
i used adhesive remover. I got it at Home Depot, but I forget what it is called. It worked great. I just poured it on, spread it around where i needed it, let it sit for 15-20min and wiped/scrubed off and sprayed out with water. (2000 Civic Si) I had a drain hole in the bottom of my trunk.
I'll try to find the name of the product for everyone.
Modified by ajjohnsonnc1 at 8:39 PM 4/18/2004
Old Apr 18, 2004 | 11:53 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX &raquo;</TD></TR><TR><TD CLASS="quote">
My how-to: https://honda-tech.com/zerothread?id=525936</TD></TR></TABLE>
nice write up!
Old Apr 19, 2004 | 06:02 AM
577HondaPrelude's Avatar
Default Re: Suggestions to removing the tar left behind from sound deadening (vapor)
About how much weight in sound deadening crap is there in an average 2 door honda anyway?
Old Apr 19, 2004 | 06:33 AM
Erik95LS's Avatar
Default Re: Suggestions to removing the tar left behind from sound deadening (577HondaPrelude)
I used the 3M adhiesive remover pictured above and a rag and it all came right off very very easily.
Old Apr 19, 2004 | 08:49 AM
Default Re: Suggestions to removing the tar left behind from sound deadening (Erik95LS)
i went to home depot and got the adhesive remover and it worked really well. but now i found out i have some rust in the driver side floorboard (its an 85 corolla so im not that surprised). i was still wondering though if that orange sticky residue can be removed. there is one long seem of it running in the back seat across the car and other various patches.it seems like its there to cover up the line where two pieces of the floor come together. i dont wanna remove it if its there for structural rigidity.
Old Apr 19, 2004 | 01:19 PM
h22mark's Avatar
Yeah dryice works the best I am doing that right now, and it would be best to do it at night becuase in warm weather the tar tends to heat up more and stick. Also I found a chemical that removes the tar left over pretty well, its made by a company called Giachem, forgot the name of the chemical but if intrested PM me the guy gave me the chemical for free, so if you wanted it you probably pay for shipping unless you live in NoVA. This chemical has no nasty smell, in fact it smells like oranges, and is enviromentally safe to pour in the grass.
Old Apr 19, 2004 | 03:42 PM
The Adhesive remover i got from Home Depot is called Klean Strip thick brushable paste. It worked great and today i finished wet sanding the back half of the interior. I am ordering some EBP in a spray can from paintscratch.com
on a side note has anyone used this stuff before? Its only $65 shipped for primer, base-coat and clear-coat. I figure ever if i screw it up its only $65 and it will probably look better than my sanded down ugly ebp and primer mess that honda left for me under the SD.
