aftermarket LSD
Old Apr 4, 2004 | 05:16 PM
showbiz's Avatar
Default aftermarket LSD
Does anybody make non factory LSD for a 97 to 01 or any h22 prelude transaxle
Old Apr 4, 2004 | 05:22 PM
NoLipRacen's Avatar
Default Re: aftermarket LSD (sedanman)
quaife makes units that will fit, if you have a 5 spd. there are several other manufactures that make aftermarket lsds like kaaz
Old Apr 4, 2004 | 05:35 PM
DIE DIE's Avatar
how much do those usually go for?
Old Apr 4, 2004 | 05:51 PM
577HondaPrelude's Avatar
Default Re: (seecretninja)
quife diff goes for about $900. Clutch type diffs go for much less at about $300 but they will wear out over time.
$400 to $800 install cost if you don't do it yourself.
Old Apr 4, 2004 | 07:29 PM
fastest's Avatar
Default Re: (577HondaPrelude)
dude i would love to put lsd in my trany i got a h22a in my civic hatch...who knows some good prices 400 to 800 is pretty good installed anyoine no who i coudl go to..
Old Apr 4, 2004 | 08:06 PM
Kal's Avatar
Kal
Default Re: (fastest)
i don't think installation at some shop would be cheap.
Old Apr 4, 2004 | 09:34 PM
eric416's Avatar
Default Re: (Kal)
how hard is it to install
Old Apr 4, 2004 | 09:51 PM
bad-monkey's Avatar
Default Re: (eric416)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eric416 &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to install</TD></TR></TABLE>
install isn't too easy. it involves taking apart your transmission (after taking it out) and doing a bunch of stuff like pressing out the speedo ring, and testing pre-load on the diff etc, etc.
i think the cheapest/easiest way to do the install is to drop the tranny out yourself if you're mechanically inclined, and taking the tranny itself to a shop for the lsd to be installed. this will save you about 6 hours of labor * labor rates at a shop.
with that in mind, installing a diff is no small thing, so you shouldn't cheap out on your LSD. IMO, quaife and kaaz are the only 2 diffs worth buying for an h22 tranny, and they're both expensive. a quaife can be found for ~800, though you may find deals (i got mine for $600), and a kaaz will cost around 1200 (i think...)
it's a great upgrade though.
Old Apr 4, 2004 | 10:58 PM
MindEracer's Avatar
Default Re: (bad-monkey)
I got my KAAZ LSD for 900+ about a year and a half ago.. Just so you know.
I like very much!!! deff. worth the mod..
Old Apr 5, 2004 | 06:37 AM
iakona's Avatar
CUSCO LSDs as well.
Old Apr 5, 2004 | 06:55 AM
bad-monkey's Avatar
Default Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">CUSCO LSDs as well. </TD></TR></TABLE>
oh yeah i forgot about cusco.
there's also the JDM and ATR trannies that have an OE LSD.
Old Apr 8, 2004 | 07:52 PM
fastest's Avatar
can u give me some links or guys tha tdo it or companys tt i could get this lsd from? thanks
Old Apr 8, 2004 | 09:04 PM
Variable J's Avatar
try optionsautosalon.com
Old Apr 9, 2004 | 03:06 AM
95PreludeSi's Avatar
Default Re: (Variable J)
How does the stock LSD(M2B4) compare to the Quife or Kaaz. Just wondering because I'm going to do a H22 swap soon, and its only 300$ extra for the JDM LSD. Seems like this would be a lot cheaper than adding an aftermarket LSD.
Old Apr 9, 2004 | 05:08 AM
iakona's Avatar
Default Re: (95PreludeSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PreludeSi &raquo;</TD></TR><TR><TD CLASS="quote">How does the stock LSD(M2B4) compare to the Quife or Kaaz. Just wondering because I'm going to do a H22 swap soon, and its only 300$ extra for the JDM LSD. Seems like this would be a lot cheaper than adding an aftermarket LSD.</TD></TR></TABLE>
i'll let you know as soon as installation is finished. the JDM one works really well though.
and for where to get them:
http://www.napsusa.com for the Cusco
Quaife, you can find here on the board from an advertiser.
Kaaz is pretty easy to find too.
Old Apr 9, 2004 | 05:33 AM
fast4w$'s Avatar
The Quaife is the single most important mod I've installed on my car to date. Its a night and day difference.
The difference in the Quaife compared to the others is that the Quaife is gear type. Kaaz, Cusco and Honda are clutch type. The Honda one is just not as robust as the Kaaz and other aftermarket units, but its still a GREAT mod and at $300, you should do it. The Quaife is one of the best options because its gear type doesnt need to be rebuilt, and has a lifetime warranty. Kaaz, Cusco and Honda can wear over time.
Old Apr 9, 2004 | 06:11 AM
Default Re: (FaS4wS)
BTW: There is a really good in depth article in Grassroots Motor-sports about all types of limited slip diffs, this month.
Old Apr 9, 2004 | 06:53 AM
Cool, I haven't read mine this month yet.
I think I'll probably have to go that route with the swap, I only plan to do I/H/E. I'm sure the stock one we'll hold up decently.
Old Apr 9, 2004 | 07:58 AM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FaS4wS &raquo;</TD></TR><TR><TD CLASS="quote">The difference in the Quaife compared to the others is that the Quaife is gear type. Kaaz, Cusco and Honda are clutch type. The Honda one is just not as robust as the Kaaz and other aftermarket units, but its still a GREAT mod and at $300, you should do it. The Quaife is one of the best options because its gear type doesnt need to be rebuilt, and has a lifetime warranty. Kaaz, Cusco and Honda can wear over time.</TD></TR></TABLE>
actually i think the honda LSD is a helical gear type LSD.
Old Apr 9, 2004 | 09:33 AM
Old_Nocturnal's Avatar
I drive the hell out of my Prelude both on and off the track making more than twice the stock horsepower to the wheels... Having that said, I am running phantom grip LSDs... Notice I said LSDs, as in multiples... I swap my LSD every 6 months to a year. I have been running this setup for approx 2 years now, and I have put two in my car. Total price for both? $300.00. That's $150.00 a piece for those of you that are math challenged
I went with the mindset that I would try the Phantom Grip due to price before I went with Quaife. I have driven both, and even though the PG doesn't have the lifespan, I prefer the feel of the Phantom Grip.
These are just my opinions, feel free to agree or disagree
Old Apr 9, 2004 | 10:51 AM
fast4w$'s Avatar
Default Re: aftermarket LSD (Nocturnal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">
actually i think the honda LSD is a helical gear type LSD. </TD></TR></TABLE>
you are correct...sorry
Old Apr 9, 2004 | 11:03 AM
jc836's Avatar
Quaife and KAZZ. I like the Quaife-virtually no maintenance and a really strong warranty. For more on LSDs take a look in the current issue of GRM.
Old Apr 9, 2004 | 05:07 PM
fastludeh22's Avatar
Default Re: aftermarket LSD (jc836)
ive had my oem lsd for awhile now. prob bout 2 years worth of driving. the last 5-6k ive been boosted, still holding up great. in 2 weeks we'll see what it thinks of 500+whp.
it stays pos doing a burnout w/bf drags, first and second. it will drag the back tires before it goes peg (which it never has yet)
Old Apr 9, 2004 | 05:47 PM
CBR's Avatar
CBR
If you're a JDM fanatic, don't forget about SPOON. They also make a clutch type LSD for the H22s.
Old Apr 10, 2004 | 10:02 PM
fastest's Avatar
Default Re: aftermarket LSD (CBR)
ok so tell me wats the lsd tha tis a good price and good product ...there are so many whtich one should i get and please give me a phone number or links? thanks
