Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Explain the reason for softer shock settings in rain?
Old Apr 4, 2004 | 04:42 PM
CivicSiRacer's Avatar
Default Explain the reason for softer shock settings in rain?
Today it was cold (40'ish degrees) and wet on our runs. I'm running a 2000 Honda CIvic Si on Azenis (205/50x15") on 15x7" wheels, Ground Controls 350f/400r, on Koni Yellows, stock sway bars, bushing all around and 0 toe front and rear, and camber set to -2.2f and -2.0 r.
My pressures were down to 30f/36 rear and my car was pushing like a pig! Shocks were at 1 turn front and full turn rear. And the car just kept skipping and understeering. Why does having shocks full soft work better? Help me understand the dynamics behind it.
Old Apr 4, 2004 | 05:29 PM
Outrun's Avatar
Default Re: Explain the reason for softer shock settings in rain? (CivicSiRacer)
Well, generally you run softer spring and damper rates in the wet to maintain a good mechanical grip. As for explaining the physics behind it...that's something I can't do. I'll try to find my book on racecar dynamics as it explained how a softer setup helps in the wet.
Old Apr 4, 2004 | 06:36 PM
.RJ's Avatar
.RJ
Less grip = less weight transfer
Old Apr 4, 2004 | 06:59 PM
GSpeedR's Avatar
Default Re: Explain the reason for softer shock settings in rain? (.RJ)
As .RJ said, you have less grip so you will be too overdamped with your dry shock settings.
Zaraki
Suspension & Brakes
Apr 15, 2012 02:56 PM
Blue Si #72
11
Mar 16, 2005 07:34 PM
ACRXGuy
10
Mar 27, 2003 10:45 AM
VTECAcuraGSR
13
Sep 11, 2002 07:12 AM
1fastGSR
Jul 30, 2001 07:21 AM
