F/S Nordskog digital 0-16psi boost gauge with sending unit
.2 5/8" diameter.
·Displays 0-16 PSI in 1lb. increments for precise readings at low boost levels.
·Microprocessor controlled for accuracy and dependability.
Recalls highest reading and lowest reading.
·Utilizes a remote sender for safe, easy, in-dash installation. Requires S8424 Sender.
·Programmable output for low boost warning. Must purchase R1000 output relay kit for use above 2 amps.
The boost gauge I'm selling is made by Nordskog performance it has 2 digital green-led read out and reads boost levels from 0-16psi. The one of the advantages of this gauge is when the car is off your not able to tell what the gauge is used for its just a black screen. Im changing to 0-30psi units now that I running more than 16psi. This gauge sells NEW for $110.00 and the sender sells NEW for 40.00 Im asking 55+shipping for the set.
Modified by Tcoupe351 at 4:07 PM 4/6/2004
Modified by Tcoupe351 at 4:08 PM 4/6/2004
Modified by Tcoupe351 at 4:09 PM 4/6/2004
u have paypal, it it a one wire hook up? everything include to use it since post says something about relay? email me at mike_fx_u@email.com i get payed tomarrow iam interested
Tcoupe351
Apr 8, 2004 06:03 PM
