If the OEM HID off of a JDM ITR blows out... What do you do?
I have currently a JDM ITR Front end with the OEM HID kit. If the bulbs die, what do you replace with. AFtermarket ones or can you only get it from Honda of Japan?
You can use oem Honda S2000 bulbs.
All oem Xenon bulbs have the same base, but you will need a D2S model for projector headlight housing. The other model D2R is for reflector headlight housing.
hth
hth
