'04 EP3 window - Auto up/down no worky
Old Apr 4, 2004 | 10:42 AM
dgreenwud's Avatar
Default '04 EP3 window - Auto up/down no worky
I have an '04 EP. I installed an intake on it and had to remove the battery to make it easier. Everything installed perfectly and runs great. My only problem is the auto up/down on my driver's window doesn't work. Any ideas on what needs to be fixed?
Old Apr 4, 2004 | 10:52 AM
Chiovnidca's Avatar
Default Re: '04 EP3 window - Auto up/down no worky (dgreenwud)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dgreenwud &raquo;</TD></TR><TR><TD CLASS="quote">I have an '04 EP. I installed an intake on it and had to remove the battery to make it easier. Everything installed perfectly and runs great. My only problem is the auto up/down on my driver's window doesn't work. Any ideas on what needs to be fixed?</TD></TR></TABLE>
You need to reinitialize it. Close the window all the way and keep holding the switch down for at least two more seconds. Then do the same going up. That should get the auto function working again.
Old Apr 4, 2004 | 11:03 AM
dgreenwud's Avatar
Default Re: '04 EP3 window - Auto up/down no worky (Chiovnidca)
Beautiful. Thanks a lot.
Old Apr 5, 2004 | 04:45 PM
TwoSaints's Avatar
did that work?
Old Apr 5, 2004 | 05:53 PM
vtekstorm's Avatar
Default Re: '04 EP3 window - Auto up/down no worky (EGCoupe)
do what Chiovnidca said hold it up for a few seconds than hold it down for a few seconds
dso
Acura TL, RL & ZDX
May 22, 2009 10:01 PM
nahonda04
10
Oct 13, 2008 08:54 AM
dan12288
Jan 5, 2008 06:52 PM
pcorad
11
Dec 21, 2003 09:53 PM
