do i want to rev 10k's
Old Apr 4, 2004 | 05:10 AM
goose21's Avatar
Default do i want to rev 10k's
I've read somewhere that when i put in skunk stage2 cams in my r with
a stock valvetrain, i can only rev up to 8500 rpm.
Is this true? But what if i put in the skunk2 valvetrain, how high will i be able to rev if i do this?
And will i make more power when reving to like 10k?
thanks
Old Apr 4, 2004 | 05:27 AM
ZygSpeed's Avatar
Default Re: do i want to rev 10k's (goose21)
Stock bottom end (pistons esp)?
I'd think a little higher compression would be needed along with those cams to make power higher than 8500 rpm.
Old Apr 4, 2004 | 05:49 AM
goose21's Avatar
Default Re: do i want to rev 10k's (zygspeed)
what would you al recomand. Valvesprings,retaners,valves,high compressions pistons?
Old Apr 4, 2004 | 05:57 AM
QCKGSR's Avatar
First of all,
you need to make sure it is even worth reving to 10k? Dont do it just because it looks cool to your passenger to watcha tach go to 10k. You will have to do indvidual tb's big compression and big cams. The guys who run n/a going like 10's run there motor out to like 10.5 -11 but they religiously tear down the motor to make sure the bottom end and top end is still holding together. My opinion is you can make more than enough power with just reving to 8500-9000. For example i had a b18c1 with gsr head, high compression pistons, skunk stage 1 cams, skunk mani,310 inj,aem cold air,dc 421,greddy sp exhaust, and made over 205whp on hondata. My gsr full body NOTHING removed went 104mph with a organic clutch that would slightly slip in betweeen shifts. just my .02
Old Apr 4, 2004 | 06:41 AM
goose21's Avatar
Default Re: do i want to rev 10k's (QCKGSR)
that was one of the things i wanted to now, if it would be worth it to rev to 10k.
But What would be the best thing to when i'm installing the skunk stage2 cams.
What do i have to get. For example: do i need other springs,retainers and what compression would be best?
Old Apr 4, 2004 | 07:05 AM
gaskleppie's Avatar
wat je ook aan je B18 aanpast, de koppelkromme stort in als je hoger gaat dan 8500rpm. Maar je kan met de skunk2's wel tot aan de begrenzer gaan. geen probleem.
Het heeft dus geen zin! Meer toeren maken geeft niet meer vermogen.
Zelfs met ITB's heeft meer dan 8600rpm geen zin.
En zeker met de langere slag van de B18 neem je heel veel risico bij meer dan 8600rpm. Het is dan ook zeker af te raden.
Sorry, guy's Its a lot easyer for me to explain this in dutch!
BTW, I agree with QCKGSR.
Old Apr 4, 2004 | 07:08 AM
gaskleppie's Avatar
geef me je mail adres en ik geef je een paar dyno's waar je het heel goed in kan zien.
Old Apr 4, 2004 | 08:16 AM
slowe6's Avatar
Default Re: (gaskleppie)
hahhaha its funny trying to reed the dutch and under stand it!
Old Apr 4, 2004 | 10:28 AM
RinBlue's Avatar
why does every idiot want to rev to 10k? reving to 8-9k is sufficient enough man. Forget all the stupid **** about reving to 10k.
but try it and see what happens and let us know!
Old Apr 4, 2004 | 10:41 AM
goose21's Avatar
Default Re: do i want to rev 10k's (RinBlue)
If you try to read my post. You'll know my question is:
do i want to rev to 10k. I never said i want to i only asked do i want to
the only reason i would ever want to rev so high
is if it would give me more power. Like i asked!!!!
So don't call me an idiot. If you cant read
Old Apr 4, 2004 | 10:44 AM
BlueR's Avatar
lol...trans-atlantic trash talking
Old Apr 4, 2004 | 10:53 AM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: do i want to rev 10k's (BlueR)
Ten grand deep
That stuff is hard to read hahahahha
Old Apr 4, 2004 | 10:56 AM
00MRSi's Avatar
You're not gonna make any power revving past 8500-9k rpm. I wouldn't even consider 10k rpm..
Old Apr 4, 2004 | 11:02 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goose21 &raquo;</TD></TR><TR><TD CLASS="quote">If you try to read my post. You'll know my question is:
So don't call me an idiot. If you cant read</TD></TR></TABLE>
Don't blame him, NY schools suck.
Contact Skunk 2 and ask them for a more definite answer, or even search or ask SGT:
http://www.skunk2.com/
As per their site:
"Stage II: Stage II profiles are more aggressive than Stage I profiles, and are designed for modified engines operating at higher rev ranges. Upgrading to Skunk2 Racing valvetrain components is required for proper operation. Stock idle and emission characteristics may be slightly compromised, but fair-to-good driveability allows them to still be used on dual-purpose vehicles. Proper tuning, an upgraded intake system, and an exhaust system are required in order to maximize the potential of these camshafts. Do not use oversized valves."
Skunk2
2050 5th street
Norco, Ca 92860
Tel- (909)808-9888
Email= info@skunk2.com
Personally, I'd stay stock. I just love the reliability.
Viel Glueck,
Anton
Old Apr 4, 2004 | 11:05 AM
goose21's Avatar
thanks you that was the thing i wanted to now.
I will contact skunk 2
Modified by goose21 at 12:17 PM 4/4/2004
Old Apr 4, 2004 | 11:38 AM
gaskleppie's Avatar
You guys want some more dutch?
Try to learn this line and tell it to your boss tomorow at work,
"He baas, ik wil je in je kont neuken"
I hope he doesn't understand dutch!!
hahaha
Old Apr 4, 2004 | 05:10 PM
RinBlue's Avatar
what kind of stupid question is do i want to rev to 10k? what did you really think when u wrote that? And on top of that i wasn't calling you personally an idiot, but i guess every person knows who they are! NY schools taught me that! LOL
Old Apr 4, 2004 | 08:57 PM
gaskleppie's Avatar
He is dutch, so maybe its a bit of a strange way to ask a question.
If you translate this into dutch its a normal question.
I'm sorry for being dutch also........
not!
Old Apr 4, 2004 | 09:44 PM
RGoose18's Avatar
Wow, another Goose!
And revving to 10K won't be very useful, good luck
Old Apr 5, 2004 | 12:03 AM
IntegraTionR's Avatar
My rev limiter stops me @ 9K...and I have a fully built bottom end and I think that's enough!!! No point to go higher...this motor is rev happy as it is...
Old Apr 5, 2004 | 12:12 AM
SoCal ITR's Avatar
Default Re: (IntegraTionR)
I would try and get more under the curve as opposed to making the curve longer.
Old Apr 5, 2004 | 12:24 AM
strepto's Avatar
Default Re: (SoCal ITR)
Eurotrash.. I am so embaressed.
Old Apr 5, 2004 | 07:43 AM
goose21's Avatar
if you knew the answer to my question why would you have to start
trash talking. I get so tired of some people just because they think they
know more about something they have the right to talk like this. If you know the answer tell me, if you don't or don't want to. Then shut up!!!
Modified by goose21 at 8:59 AM 4/5/2004
Old Apr 5, 2004 | 07:53 AM
Chris N's Avatar
Default Re: (strepto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strepto &raquo;</TD></TR><TR><TD CLASS="quote">Eurotrash.. I am so embaressed.</TD></TR></TABLE>
LOL!!
Civic*B16A3*Eg
Mar 3, 2007 02:02 PM
WeekH22#2
Jan 31, 2006 10:08 PM
egvtec
20
Aug 14, 2005 08:02 AM
CRDAONLINE
Dec 29, 2004 09:29 PM
vbspec
26
Mar 25, 2004 07:42 PM
