which camber kit replaces whole uca?
just get the spc upper balljoints. installed mine in like 45 minutes and they work great. i also pressed in the whole urethane kit while i did this . car can`t be touched in corners by anything around here.
spc adjustable upper balljoints. most alignment shops carry that brand of kits. they may have to order your specific application. i have a 91 std model and they install real easy . just remove the clip holding the balljoint in and hammer the old one out . new one pops right in and walla your done . i`m not sure on their website , just search .
spc adjustable upper balljoints. most alignment shops carry that brand of kits. they may have to order your specific application. i have a 91 std model and they install real easy . just remove the clip holding the balljoint in and hammer the old one out . new one pops right in and walla your done . i`m not sure on their website , just search . http://www.spcperformance.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheSanFrancisoTreat »</TD></TR><TR><TD CLASS="quote">aaha. im having a horrible time finding this.</TD></TR></TABLE>
Pretty sure the ones your refuring to are are the 'Vision' ones. Check http://www.jhpusa.com
If you want to order the SPC (www.specprod.com or the spcperformance site) Ultra Performance in Tucson has them available. Pricing and delivery is very good. The balljoints are one option depending on the amount you have lowered the car. We are using the eccentric anchor bolt kits on the race car (required by SCCA) and they are fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18crx »</TD></TR><TR><TD CLASS="quote">ive heard the uca type camber kits slip, both vision and skunk2</TD></TR></TABLE>
There are precautions you can take with both sets of arms - just do a search.
Just so you know the ball joint ones can only be used on 90-91 arms. So if you own a 88-89, search the junk yards for them. Ryan
Session101
Jan 30, 2004 01:15 PM
