front rotors warping
Old Apr 3, 2004 | 08:06 PM
mechengine's Avatar
Default front rotors warping
will cross drilled rotors, like brembo, stop warping. I have had this problem a few times now, and was wondering if these rotors will stop it since they are supposed to stay cooler, right?
Thanks
Old Apr 3, 2004 | 10:07 PM
96-EJ6 B18C's Avatar
Default Re: front rotors warping (mechengine)
The are less likely to warp that regular "stock" rotors...but just about any will warp if you get them hot enough...just go easy on the brakes and you will avoid the problem all together...either that or get some Willwood's!
Old Apr 3, 2004 | 10:48 PM
blah13's Avatar
Default Re: front rotors warping (96-EJ6 B18C)
If your going through rotors due to warping you probably have a seized caliper. That gets the rotor hot as *****, then when you sit at redlights etc the rotor warps where the pads are as it cant dissipate heat as well. I'd look into your calipers if this happens often. If its just 1 set thats warped then it may just be time for new rotors.
GSRacer1
Mar 10, 2011 11:54 PM
crx1856
Jul 2, 2003 01:11 PM
lazy bum shaughn
10
May 1, 2003 10:31 PM
dRuNk-dRiVer
13
Mar 20, 2003 06:19 PM
