timing belt keeps slipping and car back fires...
i was driving home when i shifted into 5th the car started bogging out and so i turned it off and started pushing it home. got home and did a search on honda-tech with the problems seemed to be the dizzy, replaced it and still same thing... saw that the timing was off so i re-did it and started it up and the timing belt keeps slipping... so i dunno what to do...
side of the cams where on one side its tight and the other is loose..
http://www.angelfire.com/clone...1.bmp
http://www.angelfire.com/clone...2.bmp
on top of the cams...
and my muffler from one of the back fires..
http://www.angelfire.com/clone...r.bmp
try replacing the tentioner. thats the only cause. your belt is loseing tention. FYI dont make the belt to tight it will make noise.
oem_certified_accord
Sep 28, 2007 11:37 AM
Cuong-nutz
49
May 1, 2005 12:52 PM
