h23 to jdm h22a swap
yo i need help on the swap.... i used my old wirng harness from my h23 and everything fits except for one plug which is close to the distributor.. can u guys tell me where is the thing going ... and one more thing the throttle body of h22a has 2 connectors and my harness on has one ... what is that connector on the top of the throttle body? thanx
do you have the plug going into the block (there is a 2nd bung on the coolant intake going into the block, to the right by the distri.)
If you have a "bung" looking thing w/ no hole. You prolly need to swap that out w/ the one that does.
pretty sure the extra wire is the distributor, i had to throw my H23 DIZZY
on my H22 just cuz its external coil to get the plugs to match up.
deathbus
Oct 13, 2010 10:30 PM
