Why do my ls's make this noise
Old Apr 3, 2004 | 05:39 PM
jaydm ferio's Avatar
Default Why do my ls's make this noise
Wasup I just got a pair of ls mesh rims for my civic. They fit fine, its just that when i turn right it makes a grind sound (Metal on Metal). When i turn left it sounds fine.I know it is not my tire rubbing on the mud flaps. Was wondering what it could be.
Old Apr 3, 2004 | 06:06 PM
BauleyCivic's Avatar
Risky Business
Default Re: Why do my ls's make this noise (jaydm ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio &raquo;</TD></TR><TR><TD CLASS="quote">Wasup I just got a pair of ls mesh rims for my civic. They fit fine, its just that when i turn right it makes a grind sound (Metal on Metal). When i turn left it sounds fine.I know it is not my tire rubbing on the mud flaps. Was wondering what it could be.</TD></TR></TABLE>
Why did you only get a pair?
That sound is probably an axle going bad...
And I have LS mesh rims on a SEDAN too y0:
Old Apr 3, 2004 | 06:09 PM
hatchling37's Avatar
Why did you only get a pair? :leftarrow: LMAO
Old Apr 3, 2004 | 07:14 PM
I dont just got a pair, i got the complete set. When I had my stock rims it never made that noise. Could it still be the axel?
Modified by jaydm ferio at 6:41 AM 4/4/2004
Old Apr 3, 2004 | 07:21 PM
itsJDMyo's Avatar
Default Re: (jaydm ferio)
i would check the CV boot on the axle to see if it's ripped or not
Old Apr 3, 2004 | 07:24 PM
Archidictus's Avatar
Unceasing Measure
Did you jack up the car on the hub assembly and bend one of the brake dust shields into the area that flexes when your suspension geometry changes (I.E. turning, bumps, etc.)? Check the hub and rotor and make sure you didn't dislodge something or pick up a pebble between so and so.
veilsides2000
Jan 24, 2005 09:34 AM
es_squared
Jun 24, 2004 01:35 AM
90-CRXSi
Jun 21, 2004 12:39 PM
shipsaeki
May 28, 2003 07:13 PM
LOwrestling2001
May 24, 2002 10:32 AM
