ICAV and Idling screw spec
hi, i have a 98 civic ex coupe d16y8, i am trying to adjust my idling screw, how do i adjust it? and what is the spec?
also how do i know if my icav is bad?
thx
thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan88 »</TD></TR><TR><TD CLASS="quote">hi, i have a 98 civic ex coupe d16y8, i am trying to adjust my idling screw, how do i adjust it? and what is the spec?
thx</TD></TR></TABLE>
-there should be a little screw right by the tb.
-are you throwing an check engine light? code 14?
yes, but once honda resetted, the engine light doesnt come back on anymore?
also how many turns should the screw be, cause i was playing around with it, and now i dunno how to set it back to spec.
thx
thx
You have to adjust the screw with the IACV 2P connector disconnected and the engine running at operation temperature.
And then look at your tach...or hook one up if you don't have one. And check the idle speed as you turn the screw.
where is the IACV 2P connector? at what rpm should i adjust to?
also what about code 14, should i even care about it if the cel doesn't come back on anymore?
thx
thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan88 »</TD></TR><TR><TD CLASS="quote">where is the IACV 2P connector? at what rpm should i adjust to?
The 2P connector is the only plug/wiring going into the IACV. Hard to miss.
I can't remember what the stock idle is...Somewhere below 1000RPM I guess.
Just remember that the engine has to be up to normal operation temperature before you do anything. Let the fan come on twice and that should tell you its ready. Or look at your water temp guage.
Yeah k the CEL is still thurr even if the light doesn't come on anymore.
Jump your service check connector for proof...it should still flash code 14.
And I was just thinking...if your IACV is indeed broken or some wiring went loose somewhere then adjusting the idle screw probably won't do very much of..anything.
Hopefully the IACV is just durrty.
when i adjust the idle screw, do i need to put silicons in it to prevent vacuum leak? i am not exactly sure, i was like ready other threads. and some people say to put silicon to prevent vacuum leak.
thx
thx
for some reason doesn't matter when position i set the screw at, the idle will eventually drop back to 650-700 rpm. do anybody have a picture at of where that screw is set about to and anybody has an aicv picture.
thx guys.
thx guys.
is there any differences of the cleaning for 5spd and automatic?
also do i need to cover the other hole? after clean the screen with carb cleaner, do i need to wape it?
thx
thx
ok, i cleaned, i used carb cleaner and clean the screen, cleaned it so that screen gril thing doesn't have any black stuff on it, and clean the other hole as well, so the inside is like white now.
So i started, but when i started, it doesn't started very good, maybe caused by the carb cleaner.
but for some reason, my rpm sometimes would go lower than 500rpm when i let the gas out when putting in neutral. also sometimes the rpm would stay at 600-750rpm and suddenly would increase rpm by around 100-200 rpm.
is this normal, i dun even remember how the rpm would be b4.
help please!!!
thx guys!!!
I appreciate all the help.
help please!!!
thx guys!!!
i have a 97 civic ex coupe. In the haynes manual is says that stock idle is 670rpm +-50rpm
Also, it says that for our ex y8 models, you don't need to disconnect the 2p connector
hope this helps some
I wouldn't put too much trust into the Haynes manual....the Helms (factory service manual) says that you DO disconnect the IACV 2p connector in order to set the base idle speed which should be around 500rpm. Upon plugging it back in, the idle should be around 700rpm.
When setting the idle on an engine equipped with a 3-wire IACV, you do NOT disconnect the 3p connector.
is that connector connects to the black round thing of the iacv?
so i will need to disconnect it and then set the idle screw to around 500rpm right?
once i finished setting the idle screw, do i need to turn off the car before plug the connector back in or just plug it back in with the car on?
thx
Modified by jordan88 at 9:43 PM 4/6/2004
thx
yes, that is the right connector after u set it just turn off ur car and turn it back on it may be good to disconnect ur battery for a minute or 2 after u do it to reset ur ecu so u have no cel stored in ur memory
i tried unplug the connector, but the car won't even startup.
also do u guys have a picture of the idle screw on the throttle body, is the line on the screw straight goes from up to down or cross left to right, cause no matter where i set it, it sit at 650-800rpm.
thx alot!!
thx alot!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan88 »</TD></TR><TR><TD CLASS="quote">i tried unplug the connector, but the car won't even startup.
thx alot!!</TD></TR></TABLE>
bump
bump
braapin127
13
Jan 29, 2014 06:18 AM
jeffbrewer80
Jun 23, 2012 05:27 AM
